Old 07-22-2003, 08:07 PM
sundarpn sundarpn is offline
Trans flush from cooler line
96 Taurus GL.
Is it possible and fairly straight fwd to flush the trans fluid in
the torque convertor by disconnecting the line to the cooler in the
front.?
Start the engine, collect one quart, shut off engine, put one quart of fresh fluid. repeat till i see clear fluid.
Any risks with this method.??
The cooler is just a pipe, with hoses commectin on both ends, what
end should i disconnect so that the fluid flows out the flexible tube?
thanks
Old 07-23-2003, 12:02 PM
someone reply???
Old 07-23-2003, 11:57 PM
Kinger87 Kinger87 is offline
sure
yea just make sure you don't run the motor too long when the fluid stops coming out, otherwise you'll kill the tranny pump. I used this same method on a 95 taurus, and it worked great.
Old 07-24-2003, 08:48 AM
Dan_in_WA Dan_in_WA is offline
Send a message via AIM to Dan_in_WA Send a message via Yahoo to Dan_in_WA
There's a procedure for this, right at the top of this page. Wait for the ad to show AMSOIL, and click on it. Look under Products and go to Transmission fluids. There's a link there telling you how. Sounds good to me!
Old 07-24-2003, 12:24 PM
The image is not showin up. Ya think i read that. thats the one that describes how to flush using the cooler line.
But to those who have done it, is it that straight fwd...
Old 07-24-2003, 06:49 PM
yes it is very straightforward, disconnect a tranny cooler line, and pump it into a bucket. helps to have one person operation the engine, unless you have a remote starter.
Old 07-25-2003, 07:53 AM
Will the fluid be pumped out when in "park"
Old 07-25-2003, 05:29 PM
YES!!!! dont try to pump it out in any other gear, yikes wouldn't want to see you crush yourself..
As long as the engine is running, the torque converter is spinning, and pumping fluid.
Trouble with oil cooler lines marshallblazer Problem Diagnosis 2 03-11-2010 08:37 PM
New radiator..can't get trans and engine cooler lines to seal bowhuntrrl Tahoe 5 10-18-2009 01:13 PM
Help Oil Cooler Lines oscales Tahoe 4 09-09-2009 08:44 PM
1998 Taurus trans cooler line Wodinator Taurus | Taurus Wagon 3 03-15-2005 11:14 PM
97 4Runner Trans Cooler lines mikiedreb 4Runner/GX470 1 03-14-2005 03:59 PM
