Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-22-2003, 03:11 PM
goatnipples2002 goatnipples2002 is offline
Need help fitting in turbo
What turbo motor will fit in my 1995 civic dx with out getting rid of my AC? I only want to run 10-12 psi so do I need to get a big turbo so it isn't being pushed to the max?
Turbo 351w E85
Old 07-22-2003, 03:42 PM
Accord_Zero's Avatar
Accord_Zero Accord_Zero is offline
Send a message via Yahoo to Accord_Zero
ONLY 10-12 PSI? What kind of engine do you have in there? My Accord's compression without upgrades will only allow about 8 PSI. And those engines are bigger than civics.
Either way, for that much boost, you should get a T3/T04 hybrid or just a T3.
Old 07-22-2003, 09:06 PM
I don't have it installed yet but I will have my uncle build up my internals first.
Turbo 351w E85
Old 07-22-2003, 09:40 PM
Damn, that's cool. My uncle knows a lot about this stuff too....only he lives about 3000 miles away.
Are you getting a new kit, or are you doing the Frankenstein method of one part at a time?
Old 07-23-2003, 10:23 AM
I'm too impatient for the piece by peice thing. I will be going custom because when you buy a kit all you're pay'n for is the tubing. Exhaust tubing cost $6 for 1.5 ft. The tubing in a kit cost about $500-$1500.
Turbo 351w E85
Old 07-23-2003, 12:28 PM
That's pretty cheap....but what material is it made out of? I got my stuff on eBay...used, but still useful. It's so much better to learn all of this yourself and buy things one at a time. Takes awhile, but you save a lot.
Old 07-23-2003, 06:11 PM
SleeperCivic SleeperCivic is offline
That's because the motor in your Accord has either higher compression or requires more fuel components to run more boost.
A T3 is nice, but look at a smaller one like a T25 off a DSM, a Greddy kit (I get them REALLY cheap), or the new Edelbrock kit.
A custom kit will save you money in the long run, but it will take a LOT more time to piece eveyrthing together. You'll also need to do a bunch of fuel mods for that amount of boost, so save your money up. You could run a conservative 8psi with an FMU on stock injectors, FMIC, and missing link. Other than that, I would stay at 7psi and below.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 07-23-2003, 09:46 PM
For the compression to run, say, 13, I'll need a new head gasket and new ignition system (which I just got).
But, yes, for 8 PSI...I already have the FMU and missing link.
I like the T3...plus it's the only flange that fits a turbo manifold for an Accord. When I need more boost, I'll switch and go custom I guess.
Old 07-23-2003, 10:26 PM
If you have a T3, you should be good up to at least 15psi. You just need to address your fuel system and timing.
Old 07-24-2003, 02:30 PM
Would the t25 or the t3 be my best net if I only want to boost to 10-12 psi?
Which has spools up faster?
Are either of them small enough to fit in a civic with A/C?
Do Drag turbo manifolds suck like everybody says or did a few people push their stuff too hard and theirs happened to break?
Turbo 351w E85
Old 07-24-2003, 03:46 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
The T25 is a very small turbo but it should be able to do 10-12 PSI, not much more. The T3 is good for about 21 PSI. Of course the T3 will take longer to spool but it will hold the boost all the way to redline. I am a big fan of the T3 turbo, but Sleeper has a good point, the new GT-25 would be a great turbo for your car.
Also, at that amount of boost you may also want to get an intercooler.
Old 07-24-2003, 04:06 PM
I don't want to push my turbo to it's limits and cause it to break sooner than expected. Is the gt-25 the same as the t25? Who is it made by garrett?
Turbo 351w E85
Old 07-24-2003, 05:12 PM
It's not the same, but it might be close. I don't think the T25 was ball bearing or had the same trim specs as the GT model. The GT might also have a larger intake housing, but I haven't compared the two.
Old 07-25-2003, 12:00 AM
ljrlude01 ljrlude01 is offline
Send a message via AIM to ljrlude01 Send a message via Yahoo to ljrlude01
if you are not on a budget get a t3/t4, a t3 spools allot faster than a t3/t4 but you'll see more gains with the t3/t4. And you'll be fine boosting on 10-12 IF THE TUNNING IS DONE RIGHT. and even better if you cna fford it, I would sugest you get a standalone ie Hondata, FAST, AEM EMS or something alone those lines.
01 Boosted Prelude
90 Nissan Skyline GTR
Mi-4
"current projects"
92 Honda Prelude,Ballade CRX
"finish project"
Skyline R34 GTR
Old 07-25-2003, 12:50 PM
I was gonna get a MAP bypass sensor the one JR makes and the safc (or vafc if I get a y8 head)
Turbo 351w E85
Need help, what turbo set up should I use on my new car? extremecorvette Forced Induction 4 04-02-2004 10:57 PM
Please I Need Help With Turbo Info jurrasic519 Integra 1 12-27-2003 04:55 AM
need help 89 turbo, cracked piston! gtkriss Maintenance 2 11-22-2003 10:59 AM
Ok, need help with turbo info... (boost - compression) sparq Forced Induction 4 03-11-2002 12:17 PM
