T-Sport questions
Hi!
I have 2 questions about 18 VVTL-I engine. 1. Did anyone try to put turbo or supercharger on it? 2. Did anyone try to put it into 7th gen Corolla? (Is it possible?) |
The *ZZ-FE engine has been turbocharged before. May not have been in a Corolla per se, but I know that it's been turbocharged in the Celica, MR-S, and Matrix. Over the past several months, there have been kits under R&D. You could likely take advantage of one of these kits to apply to your Corolla.
Regarding your second question; if you are referring to the AE101 as the 7th gen, the easiest way to do it is going with a 4A-GZE swap, then converting from supercharger to turbo. Some have even worked with the original 4A-FE or 7A-FE and built from there. Hope this helps...
Regards, ![]() Nobody can break it better than me. ![]() 88 I4 Slushie, 89 I4 5Sp, 89 V6 5Sp, 82 Corolla, 72 510, 88 Minitruck. |
blitz have a s/c for the 2zzge.... and yeah it as ben turboed as well but note that the hi cr is a little problem so you cant boost much on stock internals...
thanks for Ur help guys.
