Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 07-22-2003, 12:32 AM
Dizzyone1 Dizzyone1 is offline
Question Sentra Engine
I have a 95 sentra xe and i was wondering should i put in a 300zx twin turbo engine or just mod the one i have now?
Old 07-22-2003, 01:14 AM
GB Phoenix77 GB Phoenix77 is offline
Hold your horses....
Let's clear up a thing or two first.
I don't beleive it is possible to fit a VG30dett from a 300zx into you tiny little sentra. It's a V6 engine with different mounts, etc...
Well... correction... anything is possible with billions of $$$.
It's just not worth it.
I would keep your sentra as a daily driver. Then buy something with some potential and do an engine swap, or build up the existing.
for example...
Nissan 240sx drop in SR20det or RB series and make Silvia/skyline type.
2000 Nissan Sentra SE and drop in bluebird SR20
Mitsubishi 3000GT and upgrade to TT and build the hell out of it.
Toyota MR2 (91-95) and upgrade turbo systems.
early 90's celicas... drop in 2.7L Tacoma pickup engine and Turbo heavily.
NO HONDUHS
their are lots of fun project cars. But, if you are going to spend some dough, I wouldn't spend it on a 95 sentra.
Not hating 95 Sentra's... just saying there are better platforms
Old 07-22-2003, 11:48 AM
Cool
The reason i wanted to do a 95 sentra is that nobody really has one that will blaze around here.
So what kind of engine do you or any body suggest.
Old 07-22-2003, 11:59 AM
I would think you would be able to find a SR20det front drive for around $2000 + install. With a couple simple mods you should be able to push 250 hp. In a car as light as a 95 Sentra.. You should fly!
Another option would be to get a CA18de and turbo it. I don't remember if the CA18det comes in a front drive variety or not.
If you wanted you could get an SR20de and turbo that.
Old 07-22-2003, 02:15 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Any of those would work fine, but rememberyou'd be by far best off to get an engine from a front wheel drive car. The 300ZX TT engine is intended for a rear-wheel drive car and is mounted longitudinally in the engine bay. Front wheel drive Sentra's have the engine mounted transversely, or "sideways." The 300ZX's engine is not intended to be mounted transversely and would require VERY extensive modifications such as huge front flares and wheel track extension to allow the engine to fit.
However, Nissan also makes some incredible 4 cylinder engines ( mostly listed in the above post) that are intended to be mounted transversely or are at least compatible that way.
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 07-22-2003, 07:24 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
a bluebird or gti-r sr20det would probably give you the most bang for your buck. Apart from the engine itself you would need mounts, ecu, tranny and axles. This engine is turbo stock and built to withstand about 400whp on stock internals, it would be more than enough for anything you're planning on.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 07-23-2003, 12:53 AM
I have an automatic transmission... will i need to convert it to a manual? If not can i use the transmission i have now with the sr20det
Old 07-23-2003, 03:50 PM
Heep's Avatar
Well, your transmission might not be SR20DET compatible. In doing an engine swap, you would need to obtain the transmission that's intended to be used with that particular engine. If the engine donor car was available in either manual or auto, then you can use either one. However, some of the performance oriented Nissans were only offered with a manual transmission, so if you used an engine from one of them you would need to use the appropriate manual transmission.
Mark Brown
Old 07-23-2003, 10:55 PM
sr20de4evr's Avatar
you would probably have to swap in a b13-b14 se-r transmission. Auto or manual probably wouldn't matter, but if you're swapping the entire transmission anyway you would probably want to go to a 5-spd
'01 Black Sentra SE
'05 Silver WRX STi
Old 08-09-2003, 03:16 PM
Creagach Creagach is offline
sell it a buy an early model se-r or nx2000, then you'd have a much easier time with it
Old 08-10-2003, 05:49 PM
sentrasersr20de sentrasersr20de is offline
95 Sentra motor swap
Put a JDM motor in your 95 Sentra.
Look at http://www.redrumcustoms.com/jdm_engines.htm
SR20DET Bluebird 2.0 DOHC 16V 205HP. Engine & ECU for $2199
or
SR20DET GTI-R 2.0 DOHC 16V Turbo 235HP Engine, Trans & ECU $2999
For All Sentra Engines sarsourus Sentra | 200SX (USDM FWD) 0 05-30-2004 11:58 PM
94 Sentra Engine Blaze420 Sentra | 200SX (USDM FWD) 1 12-05-2003 10:29 AM
03 sentra engine 4sale 2.5 engine/6sp tranny streetracingfnf Sentra | 200SX (USDM FWD) 0 09-15-2003 06:53 PM
99 Sentra Engine Swaps rabidpanda Sentra | 200SX (USDM FWD) 2 06-25-2003 11:27 PM
Where To Find Sentra Engine sickhonda Sentra | 200SX (USDM FWD) 4 06-17-2003 09:59 PM
