Old 07-21-2003, 11:15 PM
Craker245's Avatar
Craker245 Craker245 is offline
BMW M3 Chop, one of my best!
Here is my latest:
This is one of my best so far...
original:
Old 07-21-2003, 11:18 PM
Craker245's Avatar
Chop:
Old 07-21-2003, 11:28 PM
spaceratk's Avatar
spaceratk spaceratk is offline
Send a message via AIM to spaceratk Send a message via Yahoo to spaceratk
superb chop i must say the only thing could be changed to me is the lower grill, just doesn't look right .
Scuze me while I kiss the sky.." - Jimi Hendrix
Old 07-21-2003, 11:31 PM
Craker245's Avatar
what do you think is wrong with it? thx btw
Old 07-21-2003, 11:37 PM
DigïTEÇ's Avatar
DigïTEÇ DigïTEÇ is offline
looks good but i have a few suggestions to help you improve. First, your grille mesh needs to have shawdows. They are too flat looking and dont have any depth. To fix this, simply darken the edges around the mesh, where light would not show because of extruding body parts. Second, the color is too saturated and also doenst show any depth. Play with the hue/saturation, variations, and layer modes if you are using photoshop. Third, the rear rim appears to be flat. You can either add a lip or find a new set of rims to make it look realistic. I hop the suggestions helped a little. Heres an example of the mesh with shadows and the yellow with layer mode set to muliply:
'In the end, we will remember not the words of our enemies, but the silence of our friends.'-Martin Luther King Jr.
Old 07-21-2003, 11:38 PM
spaceratk's Avatar
to me it looks like noise. maybe select it and turn down the brightness so that it would look more "smooth'" (you'll have black and grey an some white instead of it looking as though its composed of only white and black pixels)
(maybe its just me, i'm a bit high) j/k
Old 07-21-2003, 11:39 PM
spaceratk's Avatar
seems digitec got over what i was trying to say.
Old 07-22-2003, 06:20 AM
Slipknot's Avatar
Slipknot Slipknot is offline
Send a message via AIM to Slipknot Send a message via MSN to Slipknot Send a message via Yahoo to Slipknot
sweet!
Old 07-22-2003, 01:07 PM
Craker245's Avatar
thanks alot for the help guys! and digitech, how did you make those shadows, did you do it with airbrush?
Old 07-22-2003, 03:28 PM
spididdy's Avatar
spididdy spididdy is offline
Send a message via AIM to spididdy
clean chop just change the grill as everyone sadi and maybe clean up the graphics a lil bit like make em sharper
<-- yellow is rap...
^Green is Techno
Old 07-22-2003, 03:36 PM
spaceratk's Avatar
that i can tell you cracker245.
first select all the mesh then edit--> cut it out of the image Next go to edit--> paste. Then put the layer of the car over the layer with the mesh.
make sure you have the car layer selected then go to layer ---> layer styles and select drop shadow.
mess around with the options
(atleast this is the way i would do it)
Old 07-22-2003, 03:51 PM
DigïTEÇ's Avatar
you can do what he said OR...
I just selected the mesh, then with a large, soft brush, airbrushed black around the edges.
ANOTHER BMW Chop Blowncivic1320 Graphic Manipulation 8 12-09-2003 07:39 PM
BMW Chop Blowncivic1320 Graphic Manipulation 9 12-06-2003 07:47 AM
Cleaned up the bmw chop. check it out Bryan Vandie Graphic Manipulation 8 10-25-2003 08:47 PM
bmw chop! NortherntoucH Graphic Manipulation 12 09-03-2003 05:47 PM
