Old 07-21-2003, 12:04 PM
japer2 japer2 is offline
timing belt changes
Hi,
I have a 1988 Accord with 219,000 miles. The timing belt was last changed at 161,000 (in August 1999). I know the timing belt should be replaced after the first 90,000 miles, but then should it be every 60,000 miles thereafter or every 90,000 miles? I've asked this question of several mechanics - both independent mechanics and Honda mechanics, and gotten different answers.
Also, for a 1995 Accord, how often should the timing belt be replaced after the first 90,000 miles?
Thanks very much...
Old 07-21-2003, 01:44 PM
Accord_Zero's Avatar
Accord_Zero Accord_Zero is offline
Send a message via Yahoo to Accord_Zero
It doesn't say in your manuals? Email a Honda rep or someone like that. I'm sure it would depend on the quality of the belt too...there are some that are considered aftermarket that last longer. Those manufacturers would probably have their own specs on it.
Old 07-21-2003, 06:49 PM
abstract821 abstract821 is offline
I've always heard to change it every 70k. I'm not sure though....look deeper into this post because someone asked the question about a month ago and there were several replies...good luck!!
@dam Taylor
Old 07-21-2003, 08:23 PM
darkaccord darkaccord is offline
Send a message via AIM to darkaccord
The 95 should have it replaced every 90,000. I don't know why someone told you it needs to be replaced every 60,000 miles.
Old 07-22-2003, 08:33 AM
imfastidious imfastidious is offline
every 90K
belt + water pump
Old 09-15-2003, 10:59 PM
Michael Ladd Michael Ladd is offline
The timing belt on the 88 Accords is large by standards and doesn't need replacing until 90k. They have large teeth and last forever. Unless you run the car without oil or something like that and force it to jump time, which is incredibly hard to do. You shouldn't have any problems with your belt. Look at your water pump and tstat at 90k as well. Don't let them sell you work and parts that you don't need. Good Luck.
Old 09-15-2003, 11:57 PM
BullShifter's Avatar
Some are 60K, 90K, & 105K - I dont remember which is for what year. Only Honda t/belts should be used.
CHANGE the water pump when replacing the timing belt - cost for the water pump is only about $45 additional to the timing belt job. Water pump only is what 2.5-3.0hrs of labor + parts Most likely if your replacing the water pump other than with the timing belt is because the pump was leaking. What do you think happens when it leaks? It soaks the timing belt with coolant & it need replacing - its your choice. the $45 for the pump is well worth it, also a good time to replace the drive belts.
Old 09-16-2003, 12:42 AM
tenguzero tenguzero is offline
I JUST had my 90k Timing done a little under a month ago at my mechanic's. I paid $495- All belts and water pump.
(k) TZero publications. All rights reversed. Reprint what you like. Fnord
Old 09-18-2003, 03:42 AM
92lx 92lx is offline
expensive bit of mantainence.....a pain in the rear to do you yourself. If your money short, do it yourself....if you have little time, or you just don't have the patients...bite the bullet and get it done at a shop. Seriously, every 90,000 miles it should be replaced....I'm the paranoid type who would say 70-80,000....but only because I build motors as a hobby and those motors are expensive ;o)
- Nathan
Old 09-18-2003, 11:18 AM
90CRXZCSi's Avatar
90CRXZCSi 90CRXZCSi is offline
Send a message via AIM to 90CRXZCSi Send a message via Yahoo to 90CRXZCSi
you're supposed to change it every 90K. If you want to be on the safe side, im sure you could do every 60K...
2004 Sonic Blue Ford Ranger XLT
2001 Liquid Grey Metallic Ford Focus ZX3
1995 Integra GS-R - Parting out
Old 09-19-2003, 01:22 AM
Re: timing belt changes
- Nathan
Aren't "motors" electric
