Old 07-21-2003, 10:33 AM
gsf1200m gsf1200m is offline
autozone push button start help quick
I thought I was all set putting this in but I am not. Can somebody please go down to their car or if you know off the top of your head and tell me which color wires go where on the relay, and then where they hook up to the car.
And can you tell me which ignition wires I need to cut and which ones I only need to splice?
Thanks
Old 07-21-2003, 10:42 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
http://www.automotiveforums.com/vbul...ht=push+button
SOLD!
Old 07-21-2003, 10:49 AM
CRXsk8er CRXsk8er is offline
Send a message via AIM to CRXsk8er
hey....if you stil cant get it just get a 12volt tester and test all the wires going into the key thing......thats what i did when i hooked up the botton and moved the key thing.....just test them all and label them..
Old 07-21-2003, 10:56 AM
My biggest problem is that I dont know which color wires go to which numbers on the relay.
I got it off ebay and it has no directions.
Old 07-21-2003, 11:02 AM
Also, which wires do I need to cut, or just slpice.
Are there some that need to be connected to the swicth side or the harness side?
Old 07-21-2003, 11:10 AM
heres sum pic of the directions that i got with mine from autozone ok i got sum pics of the instructions for mine, and a pics of like a pictures they put on it i dont kno if it will help if you relay is laid out differently because it explains it by color of the wires .......as of the color of yours when i bought mine it came in red but you could change it to clear or blue.........
read #3
this is the little picture
one more
hope this helps a little if you have anymore ?s just pm me
Old 07-21-2003, 11:26 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
ok i just went down to my car....and this is how mine is hooked up
RED WIRE - SPLICED INTO HUGE WHITE WIRE (GND) *MAKE SURE BATTERY IS DISCONNECTED
WHITE WIRE - SPLICED INTO BLACK/WHITE WIRE
YELLOW WIRE - SPLICED INTO BLACK/YELLOW WIRE
hope that helps
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 07-21-2003, 12:24 PM
Ok, this is way to frustrating, I have to give up on this for a couple hours.
Last week I put in keyless entry, alarm, power windows, and it was easier than this stupid button.
Ive done everything you guys have said and it doesnt work.
Right now the car just starts with the key in the 2nd postion without pushing the button.
Ill be back in a couple hours if anybody has anything else to help me.
Thanks
