Old 07-21-2003, 12:12 AM
BioCyte BioCyte is offline
Unhappy Need Help Badly with Overheating
well.. having a really annoying problem with my 92 honda civic dx and was just wondering if anyone could help.
i tend to keep close to 3/4 of the way up the temp gauge and have no idea what is wrong. Sometimes it goes close to the red line and thats when i shut the car off.
tried flushing my coolant out, change the thermostat, change the fan switch (sensor) and nothing seems to be working. if i was gonna take it to a mechanic, they said that they will charge me 150 bucks JUST to check out what is wrong with it.
Was wondering if anybody in here have any ideas/clues of what is going on? Thx
ps: also if anybody can give me a clue where that fan sensor is? i didnt get to see where they put that part in when they changed it
Old 07-21-2003, 01:01 AM
MaxGCivic MaxGCivic is offline
Send a message via ICQ to MaxGCivic Send a message via AIM to MaxGCivic
ok, i had a cracked radiator not long ago, so I can give you some personal advice on this...
1st, try to make sure it's full of radiator fluid. If it is overheating like it is in this case this will keep it from overheating as fast.
2nd, see if you got a puddle of like green liquid under you car. Fill up you radiator. (don't run you car right before you do this or you will have radiator fluid flying everywhere when u take the cap off. it's under pressure) after you fill it up run it till it starts getting hot and the engine temp needles at like 3/4's before. Pop your hood and see if it's squirting out anywhere.
3rd, if there is not a leak check your hoses. You might have a bad hose.
If your radiator is cracked or broken basically I suggest to get another one. See if you can get one off a honda in a junk yard or find a place that sells radiators and just buy the raditor. Don't pay to have someone put it in. They tried ripping me off and telling me it'd be $100 bucks to put it in. You'd be surprised how easy they are to put in. Not much more then taking the fan off, then the radiator and a hose. (2 if you have a automatic) then put the new one in and reattach the hose(s).
Hope that helps.
Old 07-21-2003, 01:13 AM
spooleffect's Avatar
spooleffect spooleffect is offline
Send a message via AIM to spooleffect
When you flushed the coolant did you add nothing but Anti-Freeze/Coolant. If you did then thats the prob, radiator fluid doesn't transfer heat which is why you need water.
If its not that then when you added the coolant/water mix what mix% did you use. If you put just 50/50 then you do not have enough coolant. When you flush out your system it still has a bunch of water in it. So when you fill up the system you want to use a 70/30 mix in order to get it as even as possible. If you do not have enough radiator fluid in your system the your boiling point will lower and cause your car to overheat.
Too much radiator fluid = No heat transfer
Too little = Low boiling point and no freeze protection
Old 07-21-2003, 06:26 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
One trick iif you have too little coolent in the mix, since the boiling point is lowr, it to put on a high pressure radiator cap. the stock cap is 16 psi on civic's, though lots of mechanics I know of seem to try and use a 13 psi (0.9kg/cm2) cap until you demand the proper one. I know that if you have a 16 psi cap (1.1kg/cm2) and put on a high presure cap (18.5psi,, 1.3 kg/cm2) it is usually good for approx 10 degrees on the boiling point. The Higher pressure cap raises the boiling point of your coolent mix, thats why race cars use high pressure cap. Don't know if that helps but there you go.
Old 07-21-2003, 09:44 AM
Unhappy
yeah .. when i flushed my coolant out, i just put in straight rad fluid in and didnt mix any water in it at all. could that be my problem? i also looked at buying a new rad cap but i looked at my old one and it still keeps a good seal .. do i have to totally flushed my rad fluid out and add in water this time? or just put some water in the rad itself without flushing?
thx for the help guys
Old 07-21-2003, 10:46 AM
Egg_Shen's Avatar
Egg_Shen Egg_Shen is offline
Check your exhaust! if it has any white/grey smoke coming out, even a little, you may have a warped head gasket(burning rad fuild). Your temp gauge is acting exactly the same as mine did and I had a little smoke coming out the tailpipe.
It was a warped headgasket, I have extended warranty so it covered it.
Oh and the shop I brought it to didn't charge anything for just looking to find the problem, find a friendly shop that will do this.
Old 07-21-2003, 01:17 PM
hmm.. thx very much for the help Egg_Shen n to all the people who gave suggestion. im gonna go try to figure out this out myself b4 bringing it to the shop ..
hopefully it is something simple
another note to add though:
when they change my fan sensor, my car seems to be fine for the next 3 days or so .. but then everything went nuts again.. so i dont know if that info helps any at all .. sorry if i left it out before ... just remembered now
thx again
Old 07-21-2003, 07:51 PM
michaelsd16c michaelsd16c is offline
I know you don't want to hear this but I think you have a blown head. Dose the heat go up when ur moving or just when ur stop(like stoplight) I have the same problem. But one more thing have you check the water pump? also when you change the coolant did you bleed the air? If you want to see if it's the blown head or water pump.Take it to a radiator shop for a pressure check. They charge you about $50bucks.
Good luck!
Old 07-21-2003, 10:04 PM
Theres your prob..... No water mixed in with your radaitor fluid = Overheating! You need a 50%Water/50%Coolant Mix. Read my original post and pray you have not f'ed up the engine. Whatever your temp gauge said wasn't even close to telling you how much you were overheating your engine. Get the proper mix in your system ASAP!
Old 07-21-2003, 10:12 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Banned
BINGO!
dude mix it 50/50 or it will overheat again. Back when I was ignorant I changed mine with straight radiator fluid and it overheated. Daddy spread the word of the wise and my baby was fine. You don't have a warped head gasket or anything wrong with your engine.
Old 07-21-2003, 11:47 PM
i was gonig to put something about the 50/50 mix but i didn't think you'd be dumb enough to do that. (i mean that in the most respectful way.....no seriously!! )
hopefully that was your problem... next time buy pre-mixed radiator fluid. *cough dum dum cough*
Old 07-22-2003, 01:04 AM
Honda God
Yea, thats your problem right there. You used straight coolent instead of the proper 50/50 mix. Flush out the bad non-mix, put in the proper mix and there you go. If you feel the need for a new high pressure cap, they work good, besides, the blitz high pressure cap looks hella slick in a nice decorated engine bay.
Old 07-22-2003, 01:15 AM
Its pretty *dum dum* to use that stuff when you flush out your system. You end up with around a 70% Water 30% Coolant Mix. When you flush out your system you still leave plenty of water in it, so when you go to fill the system you want to use a 70% Coolant 30% Water mix to even it out as much as possible. That 50/50 stuff is only for topping off you system if you notice its a little low.
Old 07-22-2003, 04:16 PM
just flushed my rad again today and put in the 50/50 mix (well.. close to 60/40 cuz of the leftover water in the system) but still having the same problem as before .. its almost like that the problem is worse now
any other ideas what else could be the problem?
i checked my exhaust too and there is no yellow/whitish smoke coming out cuz by a warped head gasket.
Old 07-22-2003, 04:31 PM
candlaudio candlaudio is offline
Send a message via Yahoo to candlaudio
well i say if you done all that stuff and it is still overheating then your water pump is more than likely gone, im not for sure if you can check that part or not but if it is the original part on a 92, then more than likely it is no good, water pumps generally wont last 10 years so if that isn't it then hey you got a new waterpump that wont go out for a while and plus if it isn't it you can always take it back to the parts store and get a refund or keep it for a back up.....
94 honda civic dx
d154b7
pacesetter header
btm stage 2 clutch
c.a.i
short throw shifter
altezza's
gauges and bezel
interior painted
dropzone coilovers with 2" drop
205/40/16 yokahama parada's
99 honda civic ex vtec
dc header
c.a.i
dual tip muffler
