Old 07-20-2003, 02:13 PM
neunan neunan is offline
Send a message via AIM to neunan
fuel pressure riser (stillen)
im basically just looking for opinions/experience with one and if those fly well then a place to get one. gratzi
96 Accord EX 5spd coupe - black
AEM cai * DC Sports cc 4-2-1 header * GReddy EVO catback* AEM trupower pullies * ACT HDSS clutch kit * ClutchMasters 8lb flywheel * NGK blue wires * 4 wheel Brembo slotted rotors with AEM pads * 4bidden Motorsports shortshifter
pioneer deh9300 * phoenix gold zero point wiring * blaupunkt pa2100 pushing diamond audio HEX 6.5 comps in front * blaupunkt pa275 pushing power acoustik fahrenheit 6x9s in back* 5" LCD TV * 8-bit original NES
Old 07-20-2003, 03:09 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
Please be more specific, do you mean a rising rate fuel pressure regulator, or an adjustable fuel pressure regulator?
Beer tastes better upside down.
Old 07-20-2003, 09:11 PM
well i guess i was thinking a manually adjustable one, but an electronic one where you could dial in for different rpms at WOT would be even better. im kinda new to fuel management and stuff, i only have experience with bolt ons so far.
so...to answer your question directly, i dont even really know the difference :-[
Old 07-21-2003, 07:45 PM
Rising rate fuel pressure regulator - A simple method of fuel correction in turbocharged systems. These are better than nothing, but far from good. They increase fuel pressure in your fuel system as a function of manifold pressure. Basically what they do is monitor your manifold pressure and as it increases the regulator increases fuel pressure. The idea sounds good, the higher the manifold pressure, the more air is entering the engine, therefor you need more fuel to keep the A/F proper. One problem with this idea is that increasing fuel pressure 2 times will not increase fuel delivery 2 times, but somewhat less. It becomes obvious that this type of fuel correction is only viable in low to medium-low boost applications (up to roughly 9 psi), too high boost will spike fuel pressure very high (fuel pressure in a rising rate system is limited by the maximum pressure delivered by the given fuel pump). So if you turn up the boost in a rising rate system past a certain point, it is not feasable to expect the fuel delivery to keep up with you. Also, these devices work on boost pressure, regardless of RPM, so it will add the same amount of fuel at 5 psi (3000RPM) as it will at 5 psi (6000RPM), obviously at twice the RPM the engine will require twice the amount of fuel. These devices have many shortfalls (high fuel pressure, incorrect fuel correction) but are far better than nothing.
Adjustable fuel pressure regulator - They do the same thing as a rising rate FPR, but without monitoring boost, they are manually adjustable. This will add a certain amount of fuel throughout all RPM's. These are passive devices that, once set, stay at that setting, and do not vary with manifold pressure. These simply add fuel, and are useful in some applications, but are still garbage in my opinion.
Old 07-21-2003, 09:08 PM
thanks for explaining those, useful info. so what would you recommend then? an electronic AFC?
Old 07-22-2003, 06:08 AM
Veetec's Avatar
Veetec Veetec is offline
Send a message via ICQ to Veetec Send a message via AIM to Veetec
Why would you need more fuel with just some basic bolt-ons??
Old 07-22-2003, 12:44 PM
well, for one i figure it cant hurt. and i also read that it would help even though im still NA. no?
Old 07-22-2003, 01:11 PM
Veetec's Avatar
No, it won´t hurt if adjusted properly (dyno needed) but it also won´t do much with just the bolt-ons you have got on your car. If you would get a new cam or anything like that it would be another story though...
Reading high fuel pressure (carbureted) caffeineaholic Caprice 16 09-25-2010 02:55 PM
For Sale New adjustable fuel pressure regulator Malbe3 Parts for Sale 0 08-07-2010 06:32 PM
96 Tahoe Fuel Pressure Issues mcmyket Tahoe 3 09-17-2009 09:09 AM
97 Blazer low fuel pressure new pump stalls in gear ChevyFamily Problem Diagnosis 6 06-05-2009 06:12 PM
