Old 07-20-2003, 06:00 AM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
Stereo problem.
i am getting interferenec in my speakers. the volume is all the way down and i can hear my car reving and when i honk the horn it make a funny sound in the speakers. it is only when the car is running. Any ideas what it could be?
TIA
My Name is Roberto AKA. Berto
Old 07-20-2003, 08:46 AM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
are your remote wire and RC cables run seperatly?, Are your grounds connected right? Are you wires shielded properly? Those could all be answers to your problem.
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 07-20-2003, 01:15 PM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
I would check the ground first. Also, does this problem just happen when it is on AM/FM? or does it also do it when it is using the CD?
Old 07-20-2003, 01:28 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
as mentioned above...check the ground.
if there is still a problem then kinda need more info about your set-up. i'll try and catch ya on aim later
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 07-20-2003, 03:00 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
same thing happened to me lastnight, what had happened was that the speaker connection wasnt all the way plugged in at the amp. pushed it in real good and now its clear as a bell.
Old 07-20-2003, 04:05 PM
Yes the remote and rc r run together. the wire are all for car audio.
Yes it happens when it is fa/am and cd. What grounds should i check? like my amp ones?
Old 07-20-2003, 04:15 PM
Killa_CRX's Avatar
Killa_CRX Killa_CRX is offline
When Civics Attack!
Sounds like a ground loop to me. Make sure the cable you are using to ground your amp is making GOOD contact with the body of your car. Make sure the ground wire is as large or larger gauge then your power cable... also try to keep the ground cable under a foot long or shorter. If grounding multiple amps try to keep their ground cables a foot or more apart from eachother.
As for the how the RCA and Power wires are run... try to keep the power cables (and remote wire) and the RCA cables (and speaker cables) as far apart as possible.... like... power wires down one side of the car, RCA's and speaker wires down the other.... if they are run together, there is usually a static kind of sound caused by the electric/magnetic field around the power cable when the stereo is on.
Honda Enthusiast
Old 07-20-2003, 04:50 PM
Ok thank i will try fixing my ground today and let you know what happens
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
stero problems kichavez1986 Accord/TSX/Accord Hybrid 1 11-21-2007 09:15 PM
84 f150 stero problems tipp98-sean F Series 0 05-16-2007 09:59 PM
1997 Honda Accord Stero Problem rtotakoori Accord/TSX/Accord Hybrid 4 07-26-2004 11:25 PM
