Old 07-20-2003, 04:11 AM
rjslape rjslape is offline
Color codes
I bought a used 98 chevy pickup and someone put a aftermarket radio in. I am trying to put a stock one back in but someone cut the wires and there is no plug. I bought an aftermarket plug but the colors do not match. Does anyone have a copy of the color codes?
Thanks
Old 07-20-2003, 07:19 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
10 Way F Metri-Pack Series 100 (BLK)
Pin--Wire--Color-----Circuit No.--Function
------1-----GRY--------118---------Speaker Return, Left Front
------2-----TAN--------201---------Speaker Feed, Left Front
------3-----DK GRN-----117---------Speaker Return, Right Front
------4-----LT GRN----200---------Speaker Feed, Right Front
------5-----BLK--------150---------Ground
------6-----PPL/WHT--1382--------LED Dimming Signal
------7-----GRY--------8------------Instrument Panel Lamp Feed
------8-----PNK--------314---------Radio On Signal (Suburban/Utility)
------9-----YEL---------43----------Fuse Output Accessory, Type III Fuse
------10---ORN--------1140--------Fuse Output Battery, Type III Fuse
Pin--Wire--Color---------Circuit No.---Function
----11-14-----------------------------Not Used
----15------DK GRN-------835---------Diagnostic Signal--Entertainment and Comfort
----16-----DK GRN/WHT--817---------Vehicle Speed Signal--4000 Pulses per Mile
----17-----LT BLU----------115---------Speaker Return, Right Rear
----18-----DK BLU---------46----------Speaker Feed, Right Rear
----19-----YEL-------------116---------Speaker Return, Left Rear
----20-----BRN------------199---------Speaker Feed, Left Rear
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
What color and color code is this one? webslinger283 Murciélago (Murcielago) 2 07-20-2010 06:49 PM
color code drw7162 Bonneville 2 12-18-2002 09:41 AM
Fast and the furious lime green eclipse color code? ItalianTeg Exterior | bodykits | Lighting 8 01-20-2002 07:40 PM
NEED a wiring color code Towlie Engine, Transmission and Drivetrain 0 01-18-2002 12:50 PM
