Old 07-19-2003, 10:55 PM
justrelaxing justrelaxing is offline
What could be the problem?
My Intrigue will not start with out tapping the gas to floor 1 or 2 times and then starts and runs well.
Would this be a fuel filter problem or is it more serious?
Old 07-22-2003, 02:10 PM
esjones esjones is offline
Maybe it is not the pressing of the accelerator pedal that is helping the car start. Maybe it is just the delay between turning the key to on, and then to start. Why don't you try that (just wait the amount of time that it normally takes to press the pedal 2 times).
It certainly seems like a fuel issue, but might be a weak fuel pump that just needs time to build pressure. It might also be the filter, as you guess. Also, it could be the ECM, which is expensive.
Old 08-07-2003, 07:13 AM
GMMerlin's Avatar
GMMerlin GMMerlin is offline
I know stuff
Some times this problem can be repaired by simply cleaning the throttle body.
The fuel pump is controlled by the PCM through a relay.
If your car has over 30k miles and you haven't replaced your fuel filter, have it replaced soon.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again?
Got all the certifications
25 years ASE Certified Master Technician
GM WCT
Yea..I work at a DEALERSHIP....got a problem with that?
Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality)
This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video
PM Me for details
Old 08-07-2003, 09:28 PM
pcv pcv is offline
Also clean the throtle plate with a good cleaner. Replace the fuel filter and happy motoring.
NOTHING LIKE AN OLD CAR.
what is the problem with starting subaluba Sebring | Sebring Coupe | Convertible 3 09-28-2005 03:51 PM
My heater cuts out in my 2001 Buick LeSabre... what could the problem be? Bambo Jim LeSabre 1 01-05-2005 06:46 PM
the brake warning light is always on! What is the problem? hellochen Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 1 04-25-2004 04:50 AM
2001 Allroad - what are the problem areas? svbing General Discussion 0 10-12-2003 08:10 AM
