just wondering, how to tell if my blazer has keyless entry. it has power door locks, but did not come with any fobs. i bought one from the dealer, and tried all the posted ways to program the k.e. but now i wonder if my blazer has it installed. help!!!!!
I just programmed my 96 Blazer using the instructions from this post...
"My 95 Book doesn't show programming, so I went to the 96 book. As near as I can tell the vehicles are the same I'm not showing a change until 98, so from 94-97 this info should be correct. 1) Ground terminal No. 8(black/white wire) of Data Link Connector (DLC) Located under lower left side of dash. Reciever will respond by locking and unlocking doors within 2 seconds. Press any button of first transmitter to be programmed. Control module will respond by locking/unlocking all doors and activationg liftgate release 2) Press any button of second transmitter to be programmed. Control module will again respond by locking/unlocking all doors and activating hatch release. Remove ground from DLC terminal 8. Transmitter operation can then be verified. Attempt all functions with remote." The terminals weren't numbered, that I saw. #8 was the one on the bottom right, I think. The doors locked and unlocked almost immediately. If they don't do that for you, it may not be installed. Page 9 of the Blazer postings has a keyless entry thread with a ton of info. One of the posts has how to add the keyless entry module. Hope this helps.
well, that one doesn't work either. im starting to wonder if it has keyless entry at all. does anyone know what the option codes are or how to read them from the glove box?
95 truck programming is different. There is a little green clip on a wire near the reciever that does the programming.
Shop Foreman Buick Pontiac and GMC dealership ASE Master Tech ASE Advanced L1 GM Master tech Licensed Aviation mechanic |
where would this clip be
Right above the keyless receiver! HTH
