Old 07-19-2003, 03:59 PM
sugarcaddy's Avatar
sugarcaddy sugarcaddy is offline
Thumbs up Another DupliColor Question(with pic)
Anyone here use the metalcast Duplicolor paints? I bought a can of yellow that will look very swank on my Honda Civic if it works right.
Scott
Fastest hunk of junk in the Galaxy.....
Old 07-19-2003, 04:24 PM
cartuner's Avatar
cartuner cartuner is offline
Make sure you primer using the dupli color flat black primer then apply the base coat the metal cast paint calls for. i learned this from using the mirage paint. best advice is try this out on a junker first and try a coat of dupli color chrome paint under the metal cast paint.
my recipe
primer-base coat- metal cast-clear coat/polish
Old 07-19-2003, 04:48 PM
Vric's Avatar
Vric Vric is offline
this paint really don't like plastic.. you need at least 2 or 3 coat of primer. Also, your primer need to be perfecly even (praticly shiny) to get a good result.
I use the Metalcast Chrome for chrome part (euh... )
I never tryed for a body... but for rimz, exaust and other small part, the best way is:
Good Primer.
Clear coat (yes clear... you need a perfectly even coat to get a good shine)
Very small coat of duplicolor.. 2 or 3 coat should do the job.
Look on the spraycan.. the instruction call for a special primer for metal cast.. if you can find it I sugest you buy it (can't find it here)
Old 07-19-2003, 05:00 PM
sugarcaddy's Avatar
Thanks for the responce's. I think I will try it out on a scap body before I go and destroy the project Im doing!
Scott
Old 07-19-2003, 05:07 PM
Vric's Avatar
Scott
real good idea.. this paint is not for plastic so you need to test it before.
I love the chrome paint, but it's hard to work with
Old 07-19-2003, 05:57 PM
Vric's Avatar
btw it's a bit off topic, but those cheap sybwoofer are not blinded.. you really should get it off near you monitor before it get all yellow in corner
Old 07-13-2004, 08:37 PM
NeonAtron NeonAtron is offline
Re: Another DupliColor Question(with pic)
does gold to magenta look good?...whats the best looking color?
