Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Suspension
Suspension setups, shocks, springs, tires, handling.
Old 11-20-2001, 06:46 PM
AznVirus's Avatar
AznVirus AznVirus is offline
Send a message via AIM to AznVirus
stock motor mounts good for DET?
do you think i should just get stock sr20de motor mounts for my DET or should i get JWT?
1.6 - The Underdog
GA16DE-T Club!
Old 11-20-2001, 08:25 PM
P10DET's Avatar
P10DET P10DET is offline
Re: stock motor mounts good for DET?
That's up to you. I'm running stock mounts.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-21-2001, 06:43 AM
AznVirus's Avatar
well, do you think they will be reliable for a long time? is there much engine roll on turns?
1.6 - The Underdog
GA16DE-T Club!
Old 11-21-2001, 02:04 PM
G22DET's Avatar
G22DET G22DET is offline
Send a message via ICQ to G22DET Send a message via AIM to G22DET
i am also using stock mounts. but i know that a 2.0L turbo engine tends to shake a bit more...i'll be switching to stiffer mounts later
Luke C.
GDA Power!
Old 11-26-2001, 08:56 PM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
Might as well get the JWT Motor mounts while your in there.
Save you some time and trouble later
How is the engine swap going anyhow, AznV?
-Phil
Old 11-27-2001, 07:39 AM
G-Forces's Avatar
G-Forces G-Forces is offline
Banned
And what would your solution be? A modified set of ES inserts?
Old 11-27-2001, 04:27 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Right now the only possible modification is the modified SE-R inserts (which i am currently running). Or fill your stock mounts with urethane (which I am in teh process of doing, already have a couple filled, and just waiting now, for them to cure). I have torn up a set of mounts already, and i don't have a turbo. But i don't think a turbo motor, and a motor with quite a few bolt ons and clutch would treat the mounts any different? As long as you go easy on the car they'll last. If you are hard on the car, they will die. Wheelhop at the track last week put the final dagger in my mounts , i'll let everyone know how the urethane turns out. So far it looks like it's going to be a very nice upgrade. Very easy too. 3M windo-weld super fast urethane Too bad it's nearly impossible to find.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-27-2001, 05:27 PM
p_r_i_m_e_r_a's Avatar
p_r_i_m_e_r_a p_r_i_m_e_r_a is offline
Send a message via AIM to p_r_i_m_e_r_a
Has this been tested before?
I'm a little doubtfull, but never heard of it working.
What is the best possible set of mounts (custom or not) for the P10.
Mounts that can handle the strip.
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 11-27-2001, 05:35 PM
JustinP10's Avatar
custom made urethane mounts. And they have been tested. If you look online, on say like yahoo. There are quite a few people who have used this product before. I've seen pages where they said road race engineering recommended, and sold them this stuff. I'm just letting my mounts harden now, I'll let you know how it turns out once they fully dry. Check out: http://www.raktron.com/misc/mt.htm
Justin McClanahan
95 G20
Old 11-27-2001, 08:55 PM
G-Forces's Avatar
Banned
That's the problem there is nothing available in the aftermarket.
Nice job Justin...I can't wait it see the results. How many tubes did you use/need?
Old 11-27-2001, 11:22 PM
JustinP10's Avatar
Well, I'm testing it on the rear mount now (the one that bolts to the firewall end of the crossmember, whatever this one is called). And I'm going to see how it does. That mount i had laying around ready to install, i just never got around to it, so i figured i'd give this 3M stuff a shot before I installed the mount. I'm kinda dumb, and i didn't fill it a little bit at a time, so i'm going to have to wait a while for it to fully cure, DOH!. But I think the wait will totally be worth it. Some globs that i had laying around that already cured are pretty stiff, i'd say about the same as the stock mounts, maybe a tad stiffer. I don't know an exact durometer of the product, but my guess is somewhere in the mid-high 80's.
Oh yeah, the saddest part is that i have the mount sitting inside my computer to cure. It's the warmest place in the apartment right now(when the case fans are turned off) and I leave my computer on 24hrs, so it'll be warm all the time hehehe... that's sad.
Justin McClanahan
95 G20
Old 11-28-2001, 07:30 AM
G-Forces's Avatar
Banned
Technically that's the right motor mount. The front of the engine is where all the pullies are.
What 'mount' did you have laying around?
I would have done the same thing in my excitement.
Old 11-28-2001, 01:28 PM
JustinP10's Avatar
Part number 11320-64j00
It's the right one. The one that attaches to the firewall side of the crossmember. I bought a new one to replace the one in my car, but living in an apartment, getting a chance to work on my car isn't as plentiful as it was when i lived at home and had a garage to work in.
Update: mount is still kinda soft where the large opening is at, but the rest of the mount is nice and solid. I can't wait!!!
Justin McClanahan
95 G20
Old 11-28-2001, 01:42 PM
G-Forces's Avatar
Banned
What happened to the old one? IIRC you make a little booboo when you modified it?
Old 11-28-2001, 02:21 PM
JustinP10's Avatar
Nothing's really wrong with it, but the SE-R insert doesn't fill the whole insert, there is still the smaller of the two openings left unfilled, and the mount was already pretty worn when i put the inserts in. It's been about a year since i isntalled the inserts, and I think the mount itself just finally gave out. I am almost positive the inserts are still ok, but i'll find out for sure when i pull everything apart later this weekend
It may be one of the side mounts that died (transmission or front mount by the pullies) but i'm not sure, yet. If the rear mount doesn't fix the rattles, then it's one of those two mounts that gave out, and in that case I'll fill those, but I don't think it's one of those mounts, just because they don't see that much abuse.
Justin McClanahan
95 G20
Pass Motor Mount Plate - Stuck... pyro4329 2nd Gen 00-05 1 11-08-2009 03:22 AM
Bad motor mount cause for transmission slip? Godofwarmike 1st Gen 95-99 3 04-15-2009 10:25 PM
B-Series Motor Mount Kit for 88-91 Civic/Crx NJ1989si '88 - '91 Civic | CRX | Wagon | Shuttlee 5 08-19-2003 06:21 PM
