Old 07-19-2003, 01:41 PM
INF3RN0666 INF3RN0666 is offline
Performane Chip Questions
Umm...can someone please explain to me in detail what it does, how it works, and some other info that you might think is useful to know? Also, does anyone know where I can get one from and how much does it generally costs? Thank you!
Sorry I had to repost this in a more general forum than a specific car forum!
Old 07-20-2003, 05:29 PM
SaabJohan SaabJohan is offline
Basicly it changes the fueling and ignition maps. Powergains are just a few percent on an NA engine, exhaust emissions usually gets higher, however fuel consumption tends to go down. Require high octane fuel.
If it's a turbocharged engine powergains are greater since boost can be increased.
Old 07-20-2003, 05:34 PM
U know something, I never understood what a turbo-charged engine is. Could u please briefly explain it to me! THANKS FOR YOU REPLY!
Old 07-21-2003, 06:43 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
http://auto.howstuffworks.com/turbo.htm
good read
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 07-21-2003, 07:10 AM
I SEE....That makes sense. It's funny kuz my friend probably has that built into his 89 Ford Probe (Just like my car, probes are no longer produced I think) and he doesn't even know what it does, LOL. He just presses the Turbo button attached to his transmition thinking that there's no system installed behind it. I guess we'll have to check that out :P.
Anyways, would you know how much a performance chip costs? Also, if anyone knows where I can get one for a 1995 Eagle Vision ESi, please tell me. I saw someone's profile with a 1994 Vision (1 year older than mine) that had a performance chip. I truely don't know where he got it from but finding parts for this car is rediculous ever since the Eagle branch in chrysler was wiped out.
Old 07-21-2003, 07:15 AM
Neutrino's Avatar
Yaya Master
what turbo button?...there is no such thing....sounds like its only an overdrive switch
unless he has a boost controler with high and low boost
(\__/)
Old 07-21-2003, 07:16 AM
I truely don't know...but I do see a performance increase in his car and a slight variation of RPM when the switch is on. We'll have to disassemble it and see where the wires lead to !
Old 07-21-2003, 07:30 AM
Neutrino's Avatar
Yaya Master
yeah i'm pretty sure its just an overdrive button....
about the chip...they ussually cost about 300
(\__/)
Old 07-21-2003, 09:53 PM
SupaStealth TT SupaStealth TT is offline
Send a message via AIM to SupaStealth TT
yeah i've heard of people talkin' about this "turbo button" on 1g eagle talons (DSM's), to me it seams rediculous. a turbo is basically on or not there is no choice. i just figured it was a button that downshifted 1 gear for more power er somethin'
Do you think anyone would be stupid enough to put a Turbo on a '99 Ford Taurus SE? You thought wrong!
Old 07-22-2003, 05:20 PM
You're probably right because the RPM increases the turn the switch into the on position. However, I don't understand how increasing the RPM gives more power, I always thought it was a lower RPM gives you a more powerful start. Or maybe i'm just confusing myself! :S *BTW...can you tell that I couldn't tell you how many valves my engine has if my life depended on it*
Old 07-23-2003, 12:29 PM
When you increase the rpm, the number of combustions will increase and this will give more power.
This is why the modern 3 litre F1 engines use up to around 19,000 rpm. At 19,000 rpm the 3 litre engine will consume the same amount of air (very simplified) as an 7 litre engine at 8000 rpm, an 16 litre engine at 3500 rpm or an 1,5 litre turbo engine at 11000 rpm (with 2,5 bar boost).
Simplified we can say that the amount of air an engine consumes per time unit will define how much fuel we can burn, and the amount of fuel we can burn will define the power the engine will make. The more power the faster the car will accelerate and the higher top speed we will get.
However, at high rpm the efficiency will drop and the engine will start to have problems to provide the cylinders with air and so on and this will cause the power to start dropping after the power peak.
power chip question boosting20psi Off-Topic 1 01-07-2004 03:17 PM
Modification and performance chip question 96Maro Camaro Discussions 1 12-29-2003 07:05 PM
computer chip question bowtiecruiser Blazer 1 12-26-2003 03:35 PM
Paint chip questions.... TypeR Engineering/ Technical 1 08-18-2002 08:41 PM
Z28 computer chip question 0utlaw Engine and Transmission 3 08-06-2002 01:08 AM
