Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 11-20-2001, 06:21 PM
mtrai760 mtrai760 is offline
Send a message via AIM to mtrai760
Post Nitrous Oxide Info- Read if ya want the know...Long
Since some people have been asking about it lately, I will post up some info for ya. Nitrous Oxide has been in automotive use since the late 1950's. It is a safe and effective way of adding power to your maxima, but like all things, abuse equals destruction, and it must not be taken lightly. When used properly, NOS can add over 100 HP and close to 200 ft/lbs of torque to your Maxima. If you want a more technical breakdown of exactly what Nitrous Oxide is, read this: http://www.holley.com/HiOctn/ProdLin...ysteminfo.html
But basically in a nutshell, NOS increases power by adding more parts oxygen and cooling down your intake charge. The best off the shelf kit to use for the Maxima is NOS kit #5124, which comes with everything you need to run a 50 shot, and with a couple small upgrades, a 60 and 70 shot too. It is a dry kit, which means only Nitrous is injected into the intake, you get your extra fuel through your injectors. A wet kit adds the fuel and nitrous together before the MAF, which is not reccomended for cars with long intake runners like the Maxima, because fuel can puddle in your intake manifold and cause an intake manifold backfire, not a good thing. There are people using a wet system, that is up to them and I am not knocking it, to each his own, these are just my OPINIONS. There is also Direct port, in which individual injectors are routed to each of the six cylinders via the intake manifold. This is the safest and most effective system, but also the most expensive and hardest to set up correctly. Now with the 50 shot, or .032 jet, you can safely run without any other mods. This is not saying you won't have any problems, you still must check your spark plugs for signs of detontation, and you may have a weak stock fuel pump. The kit takes about a day to install, and includes a fuel pressure safety switch and a full throttle switch, to ensure you have safe fuel pressure and are running WOT before NOS flows. YOU MUST NOT BYPASS THESE or all safety is gone, it's there for a reason. Most of the times you here of something bad happening from running NOS, it's because someone bypassed something. Now, if you have a 5 speed, you SHOULD be okay, depending on the condition of your clutch, but I recommend going to an ACT street clutch anyway. Auto's, get a tranny cooler and a VB mod. Can you run without it? Sure. But you already spent around $4-500 for a basic NOS setup, so why not do it right? Now, you will also want to get one step colder spark plugs, these will help prevent detonation, I recommendNGK PFR6B-11 plugs. You will also want to reduce the gap by .004 for every 50 HP you add, WITH your other mods included. Now, some other things you can get to increase your safety level are:
Window switch: Allows you to specify when you want the NOS to turn on and off via RPM modules. I'd say your best bet is 3600RPMS and 6200RPMS. You want this so you don't spray to early (bad) and not into the rev limiter (really really bad)
Fuel pressure gauge: Save some extra money and get a full sweep model, they are more accurate and it will pay off with tuning. Make sure you get an electric one, you don't want fuel in the cabin.
Air fuel ratio meter: These really are not very accurate unless you run it off it's own O2 sensor, and those units are pretty expensive, I reccomend a Tomie if you must have one.
EGT: Get this over the A/F meter. Exhaust temp is a sure fire sign if your running rich or lean. You want to be right around 810-820 degrees F. Apexi makes one that you can set to turn off your NOS if the temp gets too high, I recommend it.
Bottle heater: You need a bottle pressure of around 8-900 psi to run correctly, so get a bottle heater and you won't have to worry about it.
NOS pressure gauge: Let's ya know what pressure your at.
Bottle blanket: Helps keep that bottle warm and pressure up!
Purge valve: Used to clear your lines of air, so your NOS hits harder, or to clear the NOS out when your ready to shut the car off.
Fuel pump: I would STRONGLY recommend getting an upgraded fuel pump if you plan on going over a 60 shot, or else you run the risk of running lean. Get Walborro pump GSS342, it's specified for an eclipse, but it fit's the maxima without modication. It will flow all the pressure you could ever need, and then some. You will also need a fuel pressure regulator to go along with it, I recommend an AEM universal model.
I don't know everything about NOS, but I try and help out where I can. I'm currently running an 80 shot .042 on my 97 Auto, with a VB mod and tranny cooler. I have a window switch, bottle heater, EGT, and fuel pressure gauge, along with a Walborro pump and an AEM regulator. The highest I have seen a Maxima dyno on NOS is close to 300 HP and 400 Ft/lbs of torque, and a 100 shot run at 1100 psi, so the power potential is definetly there. My best 1/4 sor far was a 14.4 on a 50 shot with low bottle pressure. So far, the fastest confirmed Maxima is running 12's, an auto on NOS. He uses the JWT kit, which is ECU controlled, but it's only for the 95-96, and cost big bucks. Check out www.cattman.com if your interested. Hope this helped, I'm tired of typing...
5spd VLSD
15.2@92mph
180hp & 193tq
Faster than jOO!
A hunting we will go...
Old 11-20-2001, 06:45 PM
Y2KevSE's Avatar
Y2KevSE Y2KevSE is offline
Send a message via AIM to Y2KevSE
What happens when I sniff nitrous?
Maxima.org Admin
\Turbocharged...
Turbonetics ball-bearing T4/T04E 60 trim with polished compressor housing
NorCal Maximas CarDomain Site
CarDomain Site
Featured on NissanPerformanceMag.com
Old 11-21-2001, 10:19 AM
Nitrous oxide for Vehicle use contains sulfar, so you'll probably croak...
Old 11-21-2001, 03:44 PM
irvine78 irvine78 is offline
Send a message via AIM to irvine78 Send a message via Yahoo to irvine78
u'd be like this...:apuke: so don't sniff...
Maximadriver.com 2DMAX of Jan/Feb/March
Check out my new homepage!!
http://www.cardomain.com/id/irvine78
mods:Stillen/Premier custom intake, Stillen y-pipe, Stillen front strut tower bar, Stillen rear sway bar, Stillen touring front lip, Stillen side skirts and rear valence, GReddy Evolution cat-back, MSD In-line fuel pump, 2 B&M fuel pressure regulator set at 45psi with VDO read out gauge, Unorthodox racing UDP, Custom 8puck racing clutch/pressure plate, 100shot NOS, Eibach springs, KYB AGX shocks, 300ZX TT front calipers, 12.4inch 3000GT VR-4 cross drilled/slotted front rotors, custom rear superslot rotors with AXISS metal master pads, SS breaklines, red painted calipers, Joshua Tree carbon fiber dash kit, Pacesetter short shifter with MOMO knob, aluminum RAZO pedals, panasonic head unit, Alpine amp and single 12" JL sub, autometer air/fuel, oil pressure guages, Gunmetal Gray 18x7.5 AXIS SE7ENs with 225/40/18 Falken tires/19x8 WORK ESPERIO IIs with 245/35/19 Yokohama AVS Sports, front/rear clear corners, factory fog lights, factory spoiler and 00-01 SE tail lights, AE headlight conversion, JDM style yellow Raybrig blubs up front/rear, APEXi RSM.....shoot...did i leave something out?
Old 11-25-2001, 01:22 AM
That's funny, I took all that time to type this, and I still see NOS questions elsewhere...
Nitrous Oxide Sale: ZEX, Nitrous Express, NOS, Venom, TNT - FREE SHIPPING ImportCarPartPlus Eclipse 2000+ 2 12-09-2004 06:32 PM
Nitrous Oxide Groupbuy/Sale: ZEX, NX Nitrous Express, NOS, Venom, TNT, Nitrous Works ImportCarPartPlus Group Buy Market 0 06-15-2004 12:48 PM
Nitrous Oxide Groupbuy/Sale: ZEX, NX Nitrous Express, NOS, Venom, TNT, Nitrous Works ImportCarPartPlus Group Buy Market 0 06-14-2004 09:54 PM
Nitrous Oxide Groupbuy: ZEX, NX Nitrous Express, NOS, Venom ImportCarPartPlus Group Buy Market 0 06-14-2004 08:40 PM
