Old 07-19-2003, 12:25 AM
mstngcobrasvt98's Avatar
mstngcobrasvt98 mstngcobrasvt98 is offline
Send a message via AIM to mstngcobrasvt98 Send a message via Yahoo to mstngcobrasvt98
Help!?!
I've never had this happen to me ever..... I sprayed a color over my primer...and the paint Shrunk!! Well..it looks like it. Along a few of the panel lines and tape lines..the paint moved away from them. Even on the license place peice..it mived away from the edges....Is there something i did wrong or can do to fix this without stripping the body?
Just a good model of mine:
2 Fast 2 Furious Skyline
STOLEN!!!
Another go at it:
2 Fast 2 Furious Skyline.. Pt. 2
Old 07-19-2003, 12:30 AM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
I'd say you needed a few mist coats first. What kind of paint and primer?
Old 07-19-2003, 12:33 AM
annodized plastic undercoat....and then the blue annodized color...and it was a few light mist coats...i just did the heavier one today
STOLEN!!!
Another go at it:
Old 07-19-2003, 12:37 AM
Would you happen to have any pictures? I think I know what happened, but I'd like to be sure before recommending anything.
Old 07-19-2003, 12:53 AM
well...hope theses help...the silver is the part where it "shrunk"
Please be able to help.....
STOLEN!!!
Another go at it:
Old 07-19-2003, 01:55 AM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
were both paints the same brand and type? i think syndicate may have meant that.or at least i might be able to help if i knew.
Old 07-19-2003, 03:13 AM
That's rather odd. I haven't seen that before, but I can list a few things that might be the culprit.
1. Did you let the primer cure and harden?
2. Did you make sure you keep the body oil-free before painting?
3. Did you use any kind of dehydrator to fast-dry the paint?
What are the brands of the paint you used?
Old 07-19-2003, 02:53 PM
hirofkd's Avatar
hirofkd hirofkd is offline
It happened to me a few times, when I used different brands, didn't wait long enough and sprayed too much.
When it happens, it's probably better stripping the paint, and do it over.
Hiroaki Fukuda
