Old 07-18-2003, 10:15 PM
blade34609's Avatar
blade34609 blade34609 is offline
Pressure Plate Wont Line Up? Help
I took my LX tranny out and took the clutch and pressure plate off of my old D15 and tried puttin it on my new D16A6.
The bolts dont line up correctly and when I tried puttin it back on the old D15 it wouldnt line up and I just took it off of there?
Do I have to have a clutch alignment tool to do this?
If so how much would one costs?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 07-18-2003, 10:54 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
it will line up. all the pins have to go in at the same time, there cant be any angle to it
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 07-18-2003, 10:56 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
get a clutch alignment kit... nick sells em on the 4g4d store
http://4g4d.hopto.org click on 4g4d store
Old 07-18-2003, 11:28 PM
blade34609's Avatar
Ok but is it still possible to get them aligned withuot buying a clutch alignment kit?
I am in a hurry to get this engine in ASAP.
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-18-2003, 11:49 PM
H4Bangin's Avatar
yes.
Old 07-19-2003, 03:22 AM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
just go up to auto zone or advances autoparts, ask for a clutch for your car, get the plastic alignment tool out and tell them that you are going to bring it back and leave something that is semi valuable so that they will let you borrow it. If you dont have the alignment tool, then your clutch will get in the way of putting the pressure plate on. I would highly recommend that you buy another clutch and resurface the flywheel while you have the tranny out.
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
