emissions help... (hydrocarbons)
alright, i keep failing e-tests, the reason is i'm burning too many hydrocarbons... how can i fix this? and what causes it??
the limits 200, and i was at 789..... they turned the idle down 2 600 rpm and it went 2 442... it has me baffled, i need to know this asap!!
94 s-10 bagged, body dropped, 22's, suicide coupe doors, fully shaved, and soon a small block 350 2011 Silverado... Stock Daily driver
cat converter?
i have no idea, dont think so tho....
Ok, here's how you get around those pesky emission problems (ive done it a few times, but not recently...). First, get a drill and a small bit, or a hammer and a small nail will work. Second, put holes in the TOP of the cheapest pipe to replace. Put those holes in the top to keep them from easily seeing them.
Seriously though, make sure your car is warmed up, and you aren't burning anything like injector cleaner, and have newer gas in the car (like don't try to pass on 3 year old gas). If all else fails, do the first option.... |
ouch dont do that just put a new cat on i got my DOHC ZC to pass Calif emmisions like a NEW car with 20HC at idle and 22 at 2500rpm and NO Co and no like 10 nox so just go wtih a new cat it will be better than putting holes in your exhuast
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run??? BLU CIVIC- no...it doesn't have any legs |
Disconnect the PVC valve hose & plug it or bad cat. I've heard adding some alcohol to the fuel tank also helps, havent tried that one yet.
fuck
so u all seem to think its the Cat... this sux, i might as well try it, me and my dad thought me running 94 octance might have something 2 do with it
