| Search | Car Forums | Gallery | Articles | Helper | Air Dried Dog Food | IgorSushko.com | Corporate |
| Latest | 0 Rplys |
#1 | |
I have a 99 Z71 Silverado and i was wondering what is the biggest tire i can go to with a 3" body lift???
#2 | |
I have 285/75/16's on factory wheels on my suburban with a 3" lift w/o any problems.
MY brother-in-law has 305/70/16's on aftermarket wheels (approx. 1" more offset) on his 99 silverado with 3" body lift, and they rub on some sharp turns if he hits a bump while turning. I met a guy a couple of months ago with a 2001 silverado with 315/75/16's on factory wheels and a 3" body lift. He said they rub everytime he turns the wheel as far as it will go but he just learned to not turn so sharp. Sorry that is all I can help, but I noticed no one has responded so maybe that is better than nothing!! Brian |
#3 | |
thanks man
#4 | |
i got 285 75 r16s on a 3 inch bodylift hope that helps it rides really great and no rub on turns mine are bf goodrich tako
98 CAMARO SS MODS COLD AIR INTAKE FROM K&NCAMS HEADERS CHIP FLOWMASTER4.10 GEARSDRIVESHAFT K&N FILTES AND OTHER LITLE THINGS FUTURE MODS SHORT THROW SHIFTER SUPERCHARGE OR OR STROKE TO 383 1999 CHEVY SILVERADO Z71 3 INCH BODY LIFTSUPERCHARGER CHIP HEADER AND DUAL EHAUSTWITH A COLD AIR INTAKEAND ACELL WIRING |
#5 | |
yeah, I have a 1997 one ton crew cab I lifted with a 3" body lift and would like to run hummer take off wheels and tires on them but have not found out if they will work,,,they are 315/70/17, but there is alot more backspacing than stock truck wheels
#6 | |
Re: 3" Body lifts?
I have a 2k Z71 on a Performance Accessories 3" body lift with 285/75/16 Timberline M/T with 16X10 Mickey Thopmson Classic II they rub just a little when I turn very very sharpe.
#7 | |
If your using the stock rim don't go any bigger then 305/70/16.
If you have aftermarket rims go with something like a 33" 12-1/2" I bet you could fit 35" 12 1/2" if you crank the torsion bars and do a 3" body lift. I have a 2001 - 1500, I just installed a set of BFGoodrich All-terrains 285/75/16 on the stock rims (7 inch wide). They do not rub at all. I did crank the torsion bars 1/4" before I had the tires mounted, but I doubt I even had to but It raised the truck in the front 1 1/2" I think the 305/70/16 would fit on my truck no problem. |
