Go Back   Automotive Forums Car Chat > Honda > Integra
Old 07-18-2003, 02:32 PM
sickspeed94 sickspeed94 is offline
impossible?
ok, my friend has a GSR, 99 i think, or 2000. anywho... him and i were wondering if we went to a junkyard and pulled a turbo out an old ?car? what would we need, if it is even possible, to make the setup complete (and preferrably functional). and if in fact it was possible, what would be a good car to pull the turbo from??? if this was a srtupid question, ust flame me and call me a newbie... if not, any help would be appreciated.
Old 07-18-2003, 06:44 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
i dont remember the code for the turbo itself but get a turbo off an older eclipse.. its most definitely possible. im not much of a turbo guru but you'd need a turbo manifold, blow off valve, wastegate, innercooler (not absolutely necessary, but for higher boost you'd need it), oil cooler, larger oil pan, preferably higher flow injectors
you should also get a larger downpipe and wider exhaust piping. and if you want to run higher boost you'll want low compression pistons
someone correct me if im wrong with ^^^... i dont know a whole lot about turbos
Old 07-19-2003, 12:17 PM
merci beaucoup
thanks man, good lookin out
Old 07-19-2003, 12:21 PM
Fonz454 Fonz454 is offline
Send a message via AIM to Fonz454
Older Eclipse turbo would be a 14b.
Old 07-23-2003, 11:28 AM
Kilboy57 Kilboy57 is offline
It might be cheaper buying a kit then trying to piece together one from a junk yard...and ur friend's car is fairly new u might not want to put old beatup parts in it
Fonz welcome to the site
Life is a lesson; you learn it when your through
Old 07-24-2003, 01:31 AM
whoneedsvtec whoneedsvtec is offline
you'll need a turbo manifold, turbo, downpipe, wastegate, BOV, intercooler, piping, fuel management, oil lines, some sort of boost controller(maual or elec.), amungst many other things, but if you really want to do it right then get a kit, it'll have everything you need. and you dont have to worry about messing anything up.
my girlfriend calls me a car nut like its a bad thing
Old 07-24-2003, 02:34 PM
Thx Killboy, was just searching for forums, and stumbled across this site, seems like a lot of people here.
quiz impossible lamborghinineeder General Discussion 29 10-07-2013 10:27 AM
quiz impossible 2 (experts only) lamborghinineeder General Discussion 42 02-26-2003 01:14 PM
doing the impossible! taranaki COMPLETELY off-topic 17 10-21-2002 11:54 PM
almost impossible JOSE MARIA Car Modeling 0 09-09-2002 05:08 PM
Mission Impossible!!!!! ragt20 COMPLETELY off-topic 13 12-28-2001 02:07 PM
