Old 07-18-2003, 10:35 AM
myzery617 myzery617 is offline
removing door panels
Im trying to install speakes in the front door, anyone know how to remove the panels?????????
Old 07-18-2003, 11:26 AM
whiteracer whiteracer is offline
Send a message via AIM to whiteracer Send a message via Yahoo to whiteracer
undo the thing you pull to open the door from the inside. Should be a screw there. Then unscrew a screw in the arm rest on the door panel. with a little force, the door panel should come off but if there are speakers already in the door panel by your feet, you're gonna have to unhook those first. Its getting the door panel back on which isn't always the easiest. In fact, that's my question, why won't my door panel line up correctly. All the tabs went in to their holes, but the lock on the door won't lock if the panel is on cause of clearance. Also, i'm assuming since you posted it here you're dealing with a 5th or 6th gen civic. Different models might have different options, just depends.
Name's David.
Old 07-19-2003, 09:54 PM
Hermansader Hermansader is offline
Send a message via AIM to Hermansader
what year is it?
96 door panel mikeburrit01 1st Gen 95-99 3 04-24-2010 03:26 PM
removing quarter panels and doors Douglas91 Cavalier Problem Diagnosis 0 02-13-2010 03:51 PM
HOW TO: Remove Front/Rear Dash and Install Deck, Remove Door Panels Classicrocjunkie Non-Performance 157 04-25-2009 10:39 AM
How To: Remove Door Panel LifeIsPain Montana/Montana SV6 1 03-21-2009 07:08 PM
How do you remove door panel on sliding door? texhawg Caravan | Voyager 2 08-12-2005 08:52 AM
