Go Back   Automotive Forums Car Chat > Mitsubishi > Mighty Max
Old 07-18-2003, 09:20 AM
goofball_tech goofball_tech is offline
Send a message via Yahoo to goofball_tech
Question engine problems
i have a 91 mighty max, my check engine light came on about three weeks ago and and my truck started to run badly, it's almost like the truck doesn't reconize that i am giving it the gas until it is full throttle. the problem comes and goes whenever it feels like it and the check engine light comes on and goes off with bumps in the road. I have changed all plugs, wires, cap, rotor, O2 sensor. i am all out of ideas, any have any input......... anything would help..........confused:
P.S. no one in my area has a check engine code readr for my year truck it's not an OBD II and you need a special one in order to view the code. Thanx.............:
Old 10-05-2003, 06:40 PM
g54b turb0 g54b turb0 is offline
Re: engine problems
CHECK THE FUEL SYS. LINES ,T.B.,FILTERS
Old 10-28-2003, 09:55 PM
gaberz gaberz is offline
Post
It sounds to me two things:
1) "Check engine" Light on-off: switch behind odometer frame (on my '88) was defective. I got one in a Junk Yard- These cars were discontinue a long time ago -
2)Loosing Power: The carburator, I had a similar problem 2 yrs ago, I just ordered a carburator repair kit and refurbished it....Running like a "beauty" - One thing I have to say, I have not had never ever a problem with this car - Even I tease my family that my car has very seldom be in the mechanic...their new ones (other mfr's), do not leave the dealer service dpt.
Old 11-16-2003, 12:22 AM
88ram50 88ram50 is offline
Re: engine problems
Try the throttle position sensor.
Old 12-06-2003, 04:32 AM
DragonRacinImports DragonRacinImports is offline
Send a message via AIM to DragonRacinImports Send a message via Yahoo to DragonRacinImports
Re: engine problems
It could also be a rotation sensor going out, or your ignition module.
Old 01-08-2004, 01:37 PM
intensentn intensentn is offline
Lightbulb engine?
I have a 1992 dodge d50 which is the same as the mighty max. mine is the 2.4 l4 5 speed. I had the same problem as you did. I went to a salvage yard, bought a computer for it and all the problems went away. $50.00 in the salvage yard, $350.00 rebuilt! Good luck
Old 11-02-2004, 04:34 AM
blizzard_of_oz420 blizzard_of_oz420 is offline
Send a message via Yahoo to blizzard_of_oz420
sometimes its the littlest things such as pulleys or even bad gas..remember that
Old 11-03-2004, 12:25 PM
Delta Dart Delta Dart is offline
Re: engine problems
P.S. no one in my area has a check engine code readr for my year truck it's not an OBD II and you need a special one in order to view the code. Thanx.............:[/quote]
A code reader is not required to retrieve trouble codes from a 91. All you need is an analog voltmeter.
You will also need a manual to guide you in code retrieval, interpretation and troubleshooting. Component circuitry needs to be checked before replacing a part and in the case of the TPS you will need to know how to properly adjust after installation.
1998 Chevy Lumina Engine Problems? Engine Swap to 3.8 jonfit04 Lumina 12 11-10-2010 08:15 PM
02 Grand Am Hard Start when engine warm. ajbtrugreen Grand AM 3 08-01-2010 01:06 PM
1996 Olds Achieva Engine cuts out CivilWarJF Achieva 3 07-14-2009 11:26 PM
engine problems. always engine problems. alwaysproblems Fiero 2 04-09-2007 01:56 PM
b16a problem on crx, engine problem crxsirpr Let's get Technical! 0 03-02-2004 02:25 PM
