Old 07-18-2003, 03:59 AM
Davoaldo Davoaldo is offline
How to use these??
Hi just need a bit of help in using these etch parts.....
Sorry abotu thsi i'm very new to using these upgrade parts
For this one i know what 1,2,3,4 is for but from then on i have no idea where to use these other parts.....
Can you guy give me suggestion or pictures.... as example for where they are used.....
How do i use these parts A,B and C
Old 07-18-2003, 04:10 AM
Ghost_9418's Avatar
Ghost_9418 Ghost_9418 is offline
Try this link and look under the photo etch section. Also has a part on how they're made.
http://www.crosswinds.net/~modelcartech/index2.htm
Ryan
If your new to the AF modeling forum please read this : AF modeling FAQ
Current Project:
Tamiya Porsche Boxster Special Edition
Old 07-18-2003, 04:25 AM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
a, b , c are windshield wipers. they have scored lines where they should be bent. ive never bought this companies parts but is pretty standard stuff. i use studio 27 and they include directions. anyhow they are wipers and generally you cut the wiper blade from the plastic part of a model kit and wrap the PE part around it. as for the top picture. those are all different types of hood pins and it depends on type of car to decide which ones to use. generally a PE kit has many sets of pins or what ever the subject so you can use it on many kits. does this help?
Old 07-18-2003, 04:39 AM
freakmech's Avatar
after futher inspection... 7, 8, 9, on the first picture are little bolts. you can use them on the engine or body or any where a bolt might be to add realism. also more general... you need to use a CA type glue for all PE (photo-etched) parts. picture is too fuzzy to help with the other parts but i hope this helps. and remember.... when you buy an up-grade PE set like these there are always lots of extras to use on any model. i call them "universal" up-grades. you need to know about real cars to use most sets. alot of the parts you dont know what they are for might be seat belt parts that you use with plastic strips but i cant say for sure cus the pictures arent crisp enough.
Old 07-18-2003, 01:12 PM
oooooooh.......
abotu those bonnet pins some of them i have never seen before on a car eg.... 13 and 14 or 6 where do these usually go on the car??
Old 07-18-2003, 10:53 PM
hirofkd's Avatar
hirofkd hirofkd is offline
Originally posted by Davoaldo
oooooooh.......
I believe I've seen 13 and 14 in 50s and 60s race car, like Ferrari, Maserati or Jaguar. Most of them have a small front hinged engine hood, and two are used at the back corner of the hood.
6 can be found in various prototype and IMSA racers, and they're usually fastening the front or rear cowl to the bottom half of the body or chassis.
Hiroaki Fukuda
Old 07-18-2003, 10:59 PM
Major774 Major774 is offline
They look tricky to use.
Major
Mercedes-Benz CLK DTM 2000
Old 07-18-2003, 11:25 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
6 are Dzus fasteners. In real life, they are just a flathead screw (kind of) that only require a pressed 1/4 turn to open, like child safe medicine bottles. I haven't actually seen them on cars with my own eyes, just aircraft (all over the cowl or wherever the engine compartment is), though I've heard of them being used to attach underbody panels, like diffusers and the like. Hirofkd is probably right, too, though I have no idea. He seems to be a wealth of knowledge.
Old 07-19-2003, 12:59 AM
jdmstreethatch jdmstreethatch is offline
13 and 14 are tow hooks i believe.
could someone please explain to me what these "kits" are and how you get them??
can you use them on tamiya and fujimi 1/24 cars??
please explain because im new to modeling.
thanks
chris
J-Spec EK
Old 07-19-2003, 01:43 AM
freakmech's Avatar
these are Photo-etch (PE) detail kits. they are made of thin metal and are just used to add detail to any brand of model. for instance.... say your building an engine for a model and the valve covers have little molded in bolts. instead of painting these little nubs silver you can glue a PE bolt there instead to make it look more real. there available at good hobby stores, ebay, and on-line hobby stores.
Old 07-19-2003, 02:26 AM
waaaaaa coool thx guys for the detail explaination now i know where to use them hehhehe
but i don't think i'll be using 13 and 14 much cause i hardly get classic cars....
but thanks soooo much for the detail explaination
Have Any Of You Used These????? 66pontiac Car Modeling 3 07-03-2003 10:19 PM
Any one ever use these wheels? Camber Car Modeling 5 02-22-2003 08:57 PM
Anyone use these tires? Dinzdale40 Tires and Wheels 3 01-26-2003 02:54 PM
