Old 07-18-2003, 12:13 AM
walt0023 walt0023 is offline
Send a message via AIM to walt0023 Send a message via Yahoo to walt0023
MAP sensor question
ok well i got my car running better now but it still is shooting a code 3. i havnt changed the map sensor yet but my car feels way slower now. could that have to do with the map sensor? and will a d seris map sensor fit on my b16??
Old 07-18-2003, 12:21 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
The MAP Sensor should work on the B16A. Most all Honda/Acura Map Sensor on the older cars look the same to me and should all work.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-18-2003, 12:53 AM
91civicDXdude's Avatar
if you look at the ECU maps, you will find out that the MAP sensor is the #1 most important sensor in the whole car. The entire fuel and timing map depends on a precise reading from the map sensor, and if its damaged, the car will run like dog poo.
Old 07-18-2003, 05:12 AM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
haha nicely put
Old 07-18-2003, 08:31 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...maybe I missed something... (pretty typical) .. did you get a new engine or get the old one running?
SOLD!
Old 07-18-2003, 11:16 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
all the ED chassis cars use the same part number for the map sensor. from what ive found, the DA chassis integra has a different part number for its map sensor. its the one im going to be running in my hatch when i finish rebuilding.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 07-18-2003, 11:36 AM
the integra has a different map sensor becuase it is mounted on the firewall, as are 88-91 civic/CRX. the later cars, mostly OBD1 + have the MAP sensor mounted right on the top of the firewall.
Old 07-18-2003, 01:22 PM
EF You's Avatar
EF Life Giver
Originally posted by 91civicDXdude
the integra has a different map sensor becuase it is mounted on the firewall, as are 88-91 civic/CRX. the later cars, mostly OBD1 + have the MAP sensor mounted right on the top of the throttle body
i think thats what you meant to say. yeah the DC integras (94+) have the map sensor on the throttle body. all the older hondas mount them on the "control box" (thats hondas official name for it) which is a bracket on the firewall for the civic, and a bracket with a cover on the firewall for the integras. im using the map sensor from the integra, i dont know if it can handle a larger range of pressure, but i figured putting a harder hitting motor might need it.
map sensor failure symptoms bustinsails Problem Diagnosis 5 11-21-2010 08:14 PM
MAP Sensor, very very strange! SebOber Grand Cherokee | Grand Cherokee SRT8 3 03-28-2010 05:02 PM
MAP sensor question... bluemoon541 Let's get Technical! 2 05-03-2006 10:37 PM
MAP sensor question... bluemoon541 '96-'00 Civic 0 04-25-2006 05:09 AM
MAP Sensor question troy1 Grand Prix 3 01-20-2006 10:41 PM
