Old 07-17-2003, 09:22 PM
blade34609's Avatar
blade34609 blade34609 is offline
Installin Clutch Cover?
Hi,
I took off my old clutch and clutch cover off of my old D15 and attempted to put it on my D16A6.
The problem is the bolts dont match anymore even on the old D15 engine. I know they are the same cause the tranny bolts right up to it?
will I need a special tool?
Thanks
Owen
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
Old 07-17-2003, 11:20 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Are you using the same flywheel? or the one on the other engine. If it's not the same (right) flywheel then it may not line up. You may have to pull the other flywheel off and use it on the D16.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 07-17-2003, 11:25 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
What the hell is a clutch cover?
Are you talking about the pressure plate? It only bolts up on way, so keep turning it again and again until all the holes line up.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 07-17-2003, 11:27 PM
blade34609's Avatar
Yea sorry I mean the pressure plate that goes over the clutch disc.
Somebody told me I will need a clutch alignment tool to align the bolts correctly?
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
Old 07-17-2003, 11:30 PM
4G4D Store's Avatar
You need a clutch alignment tool - but if it's a 1.5l pressure plate I don't think that it will work on a 1.6l fly wheel.
Old 07-17-2003, 11:34 PM
I think all the pressure plates and clutches will fit any of the trannies. However there might be some small differences. For one I know 88 had 21 spline clutch and 89-91 had 20 splines. I think 88 had the smallest clutch, then 89 slightly bigger, then 90-91 the biggest. I assume the pressure plates would be bigger for the bigger clutch. I think you can use the big clutches as long as you get the same pressure plate.
Old 07-17-2003, 11:39 PM
blade34609's Avatar
Well my old engine is a 90 LX D15 and The new one is a 90 CRX SI engine. They should match up correct? With a clutch alignment tool.
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
D16A6 Si swap
DX 5 Speed Tranny
