Old 07-17-2003, 07:50 PM
DJ Nitrous DJ Nitrous is offline
Send a message via AIM to DJ Nitrous
Single vs. Dual Exhaust
I was wondering about the differences b/t Single and Dual Exit Exhaust
Dual will cost me 200 dollars more...is it worth it?
-= DJ Nitrous =-
Old 07-19-2003, 12:01 AM
ne one???....im gunna go with single then
-= DJ Nitrous =-
Old 07-19-2003, 01:19 AM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Go with the duals. A well designed dual exhuast system will allow the engine to breath much better than the restricted single. Though you will need to increase the airflow into the engine to get maximum benifit.
Old 08-06-2003, 12:20 PM
96Blazin 96Blazin is offline
If you go with the duals you will lose some low end torque if you have the V-6. I'd go with the duals and make up for the torque loss doing something else!
Old 08-17-2003, 05:12 PM
Rob_0126 Rob_0126 is offline
Send a message via Yahoo to Rob_0126
If you go duals(true duals now), put an h-pipe in.
It will balance out the exhaust gases between both banks of cylinders, and will give a bit more torque and power across the rpm band.
I saw a difference with the 5.0L ho in my car.
Have a good exhaust shop put it after the cat's, if you have any on there. Not sure if putting it on before them would serve a good purpose.
Robert
"Life is great, when you got a V8!"
