Old 07-17-2003, 05:02 PM
fscskaters fscskaters is offline
Send a message via AIM to fscskaters
oil
what oil r y guys using for a stock dx? im changing my oil and im having a mental block for what to use like 10 w 30 or somehing?
http://www.automotiveforums.com/vbulletin/attachment.php?s=e0866e9d79666b9d1f3e082bfe03b073& postid=955704
Old 07-17-2003, 05:04 PM
Tanked Tanked is offline
I'm using 10w-40 in my LX, although it's really supposed to use 5w-30.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 07-17-2003, 05:07 PM
GTA's Avatar
GTA GTA is offline
Whee..
I use Castrol GTX 5w-30 in my dx.
AF Bay Area Crew
RIP Melt
2008 Mitsubishi Lancer Evolution GSR
2007 Toyota Prius
I <3 and miss my 4g
Old 07-17-2003, 05:21 PM
crx hf crx hf is offline
What kind of oil should i use for my CRX SI?i was old to use 10w40.
Old 07-17-2003, 05:35 PM
GTA's Avatar
GTA GTA is offline
Whee..
use 5w-30 or 10w-30, but if you already got 10w-40 bought you can use that too, it wont hurt anything. Im pretty sure homda recommends 5w-30.
AF Bay Area Crew
RIP Melt
2007 Toyota Prius
I <3 and miss my 4g
Old 07-17-2003, 06:32 PM
riceriderjade's Avatar
riceriderjade riceriderjade is offline
i use mobil1 5w30 in my rex dx,
throw a little no smoke in to deal with my burning problem and it runs nice with it, but to be honest with you, i think just keeping the oil changed regularly is a lot more important than what kind it is.
Old 07-17-2003, 09:08 PM
91lxdreamer's Avatar
91lxdreamer 91lxdreamer is offline
Send a message via AIM to 91lxdreamer
Actually, a lot of the newer engines designed run a lot smoother on 5-30 than anything else. If you have a premium 5w-30 oil, dump that in there, but I'm not too sure if our 4th gens really fall under the category of "newer cars", but thats okay. I use premium 5 30 every time in my 91 lx, and it runs like a dream.
Old 07-18-2003, 12:32 AM
I think if the engine is in really good condition, the lighter (5w-30) will work better...slightly better power and fuel economy because of less resistance. However, the heavier 10w-40 or 10w-30 will burn slower because it can't get past worn rings and seals.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 07-18-2003, 12:48 AM
BullShifter's Avatar
5w-30 is preferred
I got a whole bunch of Penzoil Synthetic 5w-50 that I use now.
Its "normal" for a honda to burn/eat 1qt per 3,000 miles
Old 07-18-2003, 08:02 PM
blue4g2def blue4g2def is offline
Send a message via AIM to blue4g2def
It depends on where you live...5W30 has a wider range of temperatures. As in below zero to like 120F.
10W30 has a higher viscosity so its better for higher temperatures. But it kinda suckors at zero.
Old 07-18-2003, 08:10 PM
l2ice rocketz l2ice rocketz is offline
Send a message via AIM to l2ice rocketz
how well do 4th gens respond to synthetic? Jus wondering.
Old 07-18-2003, 11:22 PM
well, just in general, older cars should stay away from synthetic.
Synthetic is great if you start using it right away on a new car, but if your car is old and burns any oil (leaks in piston rings, seals) itll flow right through and will end up being a waste of money.
or am i wrong? im no expert.
Old 07-19-2003, 01:56 PM
Newer engines will benefit more from synthetic than an older engine.
If the engine leaks bad or burns oil severely then i wouldn't bother with synthetic.
There is "high-mileage" oil that actually works.
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
