Go Back   Automotive Forums Car Chat > Nissan > Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza
Old 07-17-2003, 02:56 PM
mdjx2 mdjx2 is offline
88 pulsar 1.8 want better brakes
I want to convert my back brakes into discs are there any kits so i can make the front ones larger and add discs on the back... any help would be appreciated thanks..
x2
Old 08-06-2003, 11:17 PM
Razz Razz is offline
brakes
What country are you in? Just go to a local wreckers and take the rear break assembly off one of the models that came with 4 wheel discs standard.
Old 08-09-2003, 04:01 PM
I'm in the u.s. its hard to find parts for the pulsars here. but i'm going to try and look for those thanx.
x2
Old 02-03-2004, 02:57 AM
besendesen besendesen is offline
Re: 88 pulsar 1.8 want better brakes
Try getting a rear disk breaks off a 90-94 sentra with sr20(not all sentras got rear disk breaks). I already did buy one, haven't instole yet, but it is a 99% sure bolt on. There was a pulsar and sentra in the junk yard right next to each other. The bolts and everything is identical. Don't forget to take the e brake cable off the senrta.
Old 02-03-2004, 03:51 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Re: 88 pulsar 1.8 want better brakes
You might also want to look at brakes from a van for the front end, I know several models of van sold in Japan came with a larger disc and caliper set up at the front that is a bolt on swap for some pulsar years.
2000 Mirage 1.8 Timing Belt changeout Mangoacn Mirage 0 12-18-2009 09:51 PM
HELP with N16 Pulsar Service Manual 200sxboy Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 0 03-06-2009 07:22 PM
FS: 8.8 Explorer Disc Brake Rears - in NY GSXMEN Parts for Sale 0 11-21-2007 09:52 PM
94 talon 1.8 wanting to do a swap aeflower9 Engine, Transmission and Drivetrain 2 10-22-2007 02:02 AM
want better brakes? LittleHoov Intrigue 3 01-06-2006 07:01 AM
