HI, could anyone tell me how to program a keyless remote for the 1993 Lincoln Continental? Thanks in advance, Patrick My email is [email protected] if that is convienient. Have a great day!!!
Re: Keyless remote 1993 Lincoln
These instructions will work on Lincoln Continental models 92 93 94:
Turn ignition to RUN or ACC. Momentarily jump pins in programming connector located behind the glove box. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter (up to 4 transmitters total possible). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode. These instructions will work on Lincoln Continental models 95 96 97 98 98.5: Enter 5 digit permanent entry code into the keyless entry keypad. Within 5 seconds of pressing last button of code, press the 1/2 button. All doors will lock then unlock to confirm programming mode. Press any button on 1st transmitter within 5 seconds of pressing the 1/2 button. Locks will cycle to indicate successful programming. Press any button on 2nd transmitter (up to 4 transmitters total possible) within 5 seconds of previous transmitter. (if the keypad light goes out before all transmitters are programmed, the entire process must be repeated). Press the 7/8 and 9/0 buttons simultaneously on keypad to exit programming mode. These instructions will work on Lincoln Continental models 99+: Cycle Ignition from OFF to RUN 8 times within 10 seconds, ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter ( up to 4 transmitters total possible ). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode. I have these remotes available in my Ebay store. |
Please explain the jump pins in the glove box. I can't seem to find them. And how do I jump it? Thanks!
Nevermind, I got it. Thanks!
