Old 07-16-2003, 12:36 PM
Integration Integration is offline
Unhappy Motor will not start.
Hello,
I have an 1988 Acura Integra. This car will not start, we checked the timing and it is perfect. It has been sitting for atleast a month. We replaced the clutch, filled it will new gas. The oil level is fine. We are just stumped on what is wrong. What i am asking is, to all the elders or anyone who knows, could you tell me possible problems or things i need to do or look for. Thanks alot.
Intergration
Old 07-16-2003, 12:42 PM
swedish swedish is offline
well, does it turn over? can you freely spin the crankshaft? be a little more specific, and try to pick up a manual for the car.
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 07-16-2003, 01:08 PM
yes i can turn the crank, yes i have a manual, the car will crank but wont turn over, i have no idea whats wrong, eletrical seems to be fine everything on the dash lights up, when i try to crank it, the engine make like a winding sound. that pretty much all the info i can give
Old 07-16-2003, 02:26 PM
9-deuce 9-deuce is offline
Send a message via AIM to 9-deuce Send a message via Yahoo to 9-deuce
spray some starting fluid in the intake while turning it over, if it fires then dies you have no fuel, if nothing happens then grab a screwdriver and start checking for spark
hope this helps
To my homeowners assosiation:
1. sorry for the noise
2. sorry for the noise
3. no I have not seen your cat
Old 07-16-2003, 10:18 PM
Yes i have spark, i tried what u said and nothing happend, the gage reads half a tank. Please help me anyway you can. Thanks
Old 07-17-2003, 02:29 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Sounds like fuel problem. Check your fuel pump , fuel filter and see if you can get the injectors clean. If anything, check your cap, rotor, and coil. Check the wires and spark plugs.
Old 07-17-2003, 09:06 PM
I changed the spark plugs, and new wires, new fuel filter, cleaned injectors, and it keeps winding, but will not turn over.
Old 07-18-2003, 12:57 AM
Tofuboy's Avatar
Tofuboy Tofuboy is offline
check for fuel pressure at the fuel rail.
Power is nothing without control
The fastest driver is the one with skills
95 Civic EX
83 Toyota Starlet
07 Ducati Monster S4RS
Old 07-19-2003, 09:40 AM
somedude somedude is offline
I don't know if your car will be the same as mine but the exact same thing happened to me. I took it to the shop and it took some time for them to figure the problem. It was a crankshaft sensor. The part for mine was around 600 bones. Me being thrifty i picked one up at the junkyard for 75. It works great no starting problems.
Old 07-19-2003, 10:49 AM
Hey somedue,
Where is this crankshaft sensor? And what did it take to remove it?
Old 07-19-2003, 04:37 PM
It is on the side of the motor it took removing a couple of bolts and connecting 1 plug you could easily do this yourself.
Old 07-22-2003, 01:16 PM
sweetcarz.com sweetcarz.com is offline
Banned
Send a message via AIM to sweetcarz.com
can u hear your fuel pump turn on?
could be the main relay assembly.
Old 07-22-2003, 07:00 PM
TuRboVrOoM TuRboVrOoM is offline
best i can say is check all sensors and smell (sound stupid but trust me) if burnt smell then thats a start and check all fuses in fuse box it could be a little fuse that burnt also check egnition switch and wires check starter that by your trannie under your intake also check for shortage in wires
thats the best i can say
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
