Old 07-16-2003, 12:32 PM
smilner smilner is offline
1997 one ton chevrolet crew cab 3" body lift
I have a 1997 chevrolet 1 ton crew 2WD that I installed a 3" performance acc body lift on and would like to know what the largest size tires I can run on stock rims, and what the largest size I could run with aftermarket rims ( what size backspacing would i need?)
Old 07-18-2003, 10:59 PM
Chevrolet
Not sure what happened when I posted this message, but it wound up in ford f series fourum. This question is for a 1997 Chevy one ton crew cab 4x2, lifted 3' performance acc body lift, what are the largest tires I could run on stock rims, and the largest on other rims ( with how much back spacing) Thanks
Old 08-27-2003, 12:20 PM
97 black gsx 97 black gsx is offline
Send a message via AIM to 97 black gsx
the tire shop can help u more because they can give you backspacing spec. but you should at least be able to run 31 10.50 r15 or what ever the rim size is you have
drive it like u stole it
boost it
