Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 11-19-2001, 10:15 PM
Blue93G20 Blue93G20 is offline
Idle Adjustment Screw???
Ok i set my timing today and the car is idleing at 3,000 rpm's . So i need to know how to adjust it using the screw. The first problem i'm having is i don't know where the screw is. I have a 93.5 and its a high port so any help with its location would be greatly appriciated.
93.5 Infiniti G20
JDM SR20DE
Lowered on Intrax, Hotshot Header and Hotshot CAI
15.90@88MPH
http://community.webshots.com/album/34345621pASGoo
Old 11-19-2001, 10:20 PM
P10DET's Avatar
P10DET P10DET is offline
Re: Idle Adjustment Screw???
Did you follow the procedure in the FSM? They are listed on SE-R.net.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-19-2001, 10:43 PM
Wheres the Screw...thats all i need to know....i can't find it in the service manual.
93.5 Infiniti G20
JDM SR20DE
15.90@88MPH
Old 11-20-2001, 01:44 AM
ricecube77 ricecube77 is offline
Send a message via AIM to ricecube77
Its on the AAC valve. Turn it CLOCKWISE to lower rpm's.. take it slow....
Should be located on the throttlebody, on the opposite the place where the intake filter/piping attaches.
-Phil
Old 11-20-2001, 01:56 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Go to the pass side of the car. It is in a VERY tight spot...and i have burnt myself many times...so actually what i did is put a sock on over my hand to give me a little protection from the hot stuff. Look around at the fuel rail and go down from there. It'll be behind some wire harnesses...should be a white screw about 1/2 - 3/4 inch in diameter, with a X in the middle for a phillips. It should be straight up and down. It will take a good amount of effort to start the initial turn, but after that its ok.
-Brian Jones
I got a snake man
