Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 07-16-2003, 10:40 AM
jpbmwinfo jpbmwinfo is offline
Question air conditioning musty smell
Anyone have any advice about my cars air conditioning system? When I first turn it on I get a musty smell that soon dissipates, what could be the problem? The dealer says this is normal, but I don't know about that. I tried running with A button in various positions but it didn't help. I have a 2002 325i.
Old 07-16-2003, 11:37 AM
buymeabmwm3 buymeabmwm3 is offline
Interesting that the smell doesn't stay but dissapates. Check around the intakes for the A/C system, maybe some mold or leaves or something else in there. Not really sure where this is on the E46. Maybe consult a repair manual from your local Autozone\Pep boys. How many miles are on the car? If it's still really new, it might just be breaking itself in and the smell may go away after more milage.
1992 BMW 325i conv.
FOR SALE!!
IM me for more info. $6300 /obo
2005 Ducati Monster 620 i.e.
2005 Toyota Tacoma V6 4x4 Double Cab, TRD Off-Road - FINALLY HERE!
Horsepower is 100 ewoks poking you with pointy sticks.
Torque is one wookie pulling your arms out of their sockets.
Old 07-16-2003, 07:54 PM
BMWTECH BMWTECH is offline
The smell is there most likely because the AC system is run on recirc often. It creates a mildew smell because of no fresh air to rid the moisture. Find some lysol or febreeze. Pop you hood, and in the back of the engine compartment you will see a long panel that follows the windshield. On this panel you will see three clips, one in the middle and one on each end. Turn these clips 90* Lift up on the panel and pull it towards you. You will now see a filter. It wouldn't hurt to change that either. Anyway, spray the febreeze or lysol into the vent area where the microfilter covered. Make sure you have the ac on so it sucks it in to the proper areas. Spray it a couple of times and you should be good. Just keep alternating between recirc and fresh air. Hope this helps
Old 07-17-2003, 10:33 AM
Thanks for the above info, I appreciate it, and i'll give it a try.
Old 07-17-2003, 01:53 PM
nut nut is offline
smell is from
the musty smell is from mildew that builds on your micro filter. change this and you wil be ok. the filetr is under the dash, accessable by removing the glove box. it is positioned in the centre of the dash. if you have a convertible.,.... remove it, , no need to have a filetr on convertible.
Old 07-17-2003, 02:51 PM
Ok nut, the micro filter on an e46 is under the hood. The micro filter for your car, e36 is under the dash and you don't have to remove the glove box, just remove the panel under the glove box and you will see the cover for it once you move the junction panel that is in the way.
