Old 07-16-2003, 01:04 AM
Dooodxitzxmeeh Dooodxitzxmeeh is offline
how to remove civic rear speakers
ok..well it took some time to figure out how to replace my stock 6x9 speakers in my 97 civic coupe..ok this is how it goes
1. first of all there are no screws or bolts to take off...
2. its inside the car so dont bother looking in the trunk..u will need to go under the trunk to unplug the rear brake light
3. ok fold down the back seats
4. pop off the circle round piece around where u put ur key in to fold down the seats...after the seats are down on each side there are 1 small tab on each side pop it off.
5. the back side panel u have to pop off..use a flathead to get in to pop it out..dont take it all the way out.. do it to both sides.
6. using a flathead again start to pop off the back panel easy to begin at the middle ..gota use some force..also dont be skerd it wont break on u.
7. ok here is the tricky part..the left and the right side panel wont go all the way off so the back panel will not easily slide off.hold the side panel and pull the back panel out ...u have to do this with each side..shiets a bitch to do. ok
8. now u can see the speakers and u can replace them..even harder part is putting the dame thing back together..hope this helps somebody..
1998 P71 rear speakers don't work. Moose666 Crown Victoria 0 06-26-2009 05:14 PM
Removal of rear speakers. wsmutch Lebaron 3 07-03-2008 12:11 AM
problem removing the rear speakers NateTheGreat Grand Prix 2 11-20-2005 04:57 PM
2000 civic rear speaker removal Leroyyy Interior | Audio | Security 1 05-14-2005 10:51 PM
2000 CIVIC rear speaker removal simoun_sy Car Audio 3 07-04-2002 10:13 PM
