Go Back   Automotive Forums Car Chat > Honda > Exterior | bodykits | Lighting
Exterior | bodykits | Lighting When your ready to showoff that 'H' ride, here's your forum!
Old 07-15-2003, 08:14 PM
knorsk knorsk is offline
I killed a little boy last night
I own a fifth gen accord. It is eukalyptis green, but the lower valance and side skirts aren't painted. Has anyone ever painted them and had positive results. Or does it look cheap because the stock side skirts would stand out like a bee stung panis? Just wondering if anyone ever pulled it off sweetly. Or would the golden ticket make the chocolate taste awful?
remember to keep it tucked between your legs (if ya wanna
pretend you are a woman)
You can find me at ImportRuiner.com
Old 07-15-2003, 08:27 PM
99civic03's Avatar
99civic03 99civic03 is offline
Send a message via AIM to 99civic03
Whats with the subject of the post?
Old 07-16-2003, 07:30 PM
jason11762 jason11762 is offline
Send a message via AIM to jason11762
i wanna paint mine on my civic also but im scared cause if they looked fuked up ima b really pissed
nobody really tries to go "rice" but an awful lot of people end up there
Old 07-16-2003, 08:01 PM
99civic03's Avatar
Check out www.honda-acura.net/forums under the how to section they have a sticky that tells you how to paint ur stock skirts.
Old 07-20-2003, 05:24 PM
rrazo3 rrazo3 is offline
I painted the door handles, side trim, skirts, and liscense plate area and you wouldnt believe how different it makes the car look. My civic is Frost White so its a little easier than say an emerald green to find close paint. Since all the parts were plastic, I used this paint by Krylon called FUSION. Its made for plastic and says "no prep or sanding, ultrabond" All which are good when painting these kind of things. Then I took it to the local car painting place and had them repaint that area over again. The second step is optional, but when I paited it with cans, the colors where damn close. It only cost me 30 dollars for 5 cans of paint and a roll of blue painters tape. It also took a good 3 hours to tape off everything. FYI cover up everything!!!! Overspray is a bitch! Clean all the parts to be painted with thinner or mineral spirits, and cover everything!! The Krylon FUSION comes in gloss White, black, red, blue and green. There may be others out thought. They sell it at Ace hardware or some Michaels Stores. It also works great as a pait for interior parts. Hope I helped.
Old 07-20-2003, 07:35 PM
thanks so much bro, your advice really helped, i haev an ex so the only parts that are black is the skirts and the pannels not the mirrors/door handles/ or lisence plate
Old 07-25-2003, 08:18 PM
second_glance second_glance is offline
Send a message via AIM to second_glance
I painted mine gunmetal lips also, on flamenco black pearl i like it
http://images.cardomain.com/member_i...78_27_full.jpg[/IMG] [IMG]
Old 07-27-2003, 04:19 PM
thanks bro
Old 08-01-2003, 08:03 PM
gnushit's Avatar
gnushit gnushit is offline
Send a message via AIM to gnushit Send a message via Yahoo to gnushit
painting isn't that hard to do. it's practically fool proof. i painted my skirts not so long ago (4 weeks ago). here's a little tutorial i wrote up.
MATERIALS:
1. side skirts
2. primer spray paint (i used gray color so i can tell the areas i've miss)
3. spray paint
STEPS:
1. take side skirts off car (there are 2 screws in the front wheel well and a few under the side skirts. after you unscrew the screws, you need to push the side skirts toward the back wheel well so it'll come off the car)
2. wash the dirt off side skirts
3. sand (be sure to use fine grain sandpaper for all sanding)
4. wash the dust from sanding and let dry
5. primer (spray lightly, make sure it doesn't drip)
6. sand the excess primer
7. wash the dust off and let dry
8. primer (an extra coating makes it better)
9. paint (spray lightly, make sure it doesn't drip)
10. sand the excess paint off thus making the surface smoother
11. wash the dust off with a wet rag (make sure the side skirts are dry before repainting)
12. paint (spray lightly)
13. gloss paint (spray lightly, it took over 6 coating per side to make it shiny )
14. put side skirts back on car
it turned out better than i thought. the spray paint (aluminum color) matched my car very closely. the only thing i would change next time is to use a little finer grain sandpaper and paint more coatings (ran out of spray paint ). i think i also lost a few screws
BEFORE:
DURING:
AFTER:
btw, your car looks hella nice sg
"women are like guitars, they all come with strings attached" - king of the hill
Old 08-01-2003, 08:47 PM
TheNotoriousMogg's Avatar
TheNotoriousMogg TheNotoriousMogg is offline
AF's #1 Bad Guy
Send a message via AIM to TheNotoriousMogg Send a message via Yahoo to TheNotoriousMogg
just pay too get them painted man
Darrell
thegrumpysergeant.net
Old 08-01-2003, 09:42 PM
yo i appriciate all the help guys thanks so much
Old 08-07-2003, 04:57 PM
MATERIALS:
1. side skirts
3. spray paint
STEPS:
BEFORE:
DURING:
AFTER:
Thanks GNUSHIT you did a great job on yours!
Old 08-07-2003, 09:27 PM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
second_glance
good job on the paint job...it's good to see a DIY job come out looking so good....
CL
Old 08-07-2003, 09:31 PM
gnushit
Was wondering, regarding your tutorial towards the end when you spray the moldings w/"gloss paint"...are you referring to clear coat or aluminum "gloss" paint.
If you were referring to clear coat - then your tutorial is pretty much dead on...
If you were referring to gloss paint - then I would suggest a few coats of clear coat as one of the last stages in yoru process...
CL
Old 08-08-2003, 12:08 AM
gnushit's Avatar
i was referring to clear coat
my friend painted his bumper with only 2 coats of gloss (clear coat) and it looked really tacky
Whats the best way to install side skirts? Sonic Eclipse Exterior and Wheels 8 04-06-2009 10:51 AM
stock side skirts smoke121212 Exterior and Wheels 9 07-14-2007 03:57 AM
Painting stock side skirts and door panel? draganfire '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 05-08-2004 08:03 PM
