Old 07-15-2003, 01:54 PM
chris26969 chris26969 is offline
98 Eclipse GSX
Hello,
Whats the best turbo to buy for this vehicle that i can expect a good gain from , without upgrading the fuel system?
Mods :
-3" Full Cat back exhaust
-K&N Filter
-MBC
-Upper Intercooler piping 1g Flange
-Turbo Intake
-BOV
-2 inch Drop
-Red/Orange paint job
-17" rims
-Indigo Gauges
Old 07-15-2003, 01:59 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
None.
http://www.dsmtuners.com/tuning-guide/
Go there. Read. Learn.
SUPPORTING MODS FIRST!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!
Kris
2012 Genesis Coupe 2.0t
Old 07-15-2003, 02:03 PM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
yea lando is right..
why not up grade the fuel sys..
if you wnat to run the maximum efficenty of a turbo you must have the right amount of FUEL and AIR going into you car.. me personally i would do my boltons then my fuel sys b4 upgrading to a bigger turbo.. bigger isnt always better.. just do all the bolt on to the gsx and do your fuel sys and up the boost to 14psi and if you are still not happy then only then get a
BIG 20G
1
Shift_BOOST
97 s14
Old 07-15-2003, 03:46 PM
i have the regular bolt ons. Someone told me i can throw in a Big 16G and get a good 60hp increase ,without any fuel mods.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-15-2003, 03:49 PM
"someone" is an idiot. What are "all the bolt ons"? I hope its not your mod list in your sig....
Did you even click on my link to the Tuning Guide?
Kris
Old 07-15-2003, 03:51 PM
i didnt say i had all , i said i have regular bolt ons.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-15-2003, 03:54 PM
List what you have, and we'll help you from there. At LEAST look at the link I gave you...its fairly comprehensive.
Kris
Old 07-15-2003, 03:57 PM
See , i have already looked there and im part of there forum. Yet I was wondering which turbo will give me a good potential increase / give me more HP without changing fuel management for the time being.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-15-2003, 06:15 PM
turbo2nr's Avatar
look chris bottom line do your fuel sys and supporting mods.. and then up grade the turbo if you wnat to run maximum boost on your motor.. and if you want you car to preform well and efficently get the supporting mods listed in lando's link.. dont go cheap do the supporting mods!
nuff said
1
Shift_BOOST
97 s14
Old 07-15-2003, 06:53 PM
zer0bot's Avatar
zer0bot zer0bot is offline
get yourself a datalogging program(e.g. pocketLOGGER or tunerstein), to check that nasty knock and to see if you are running rich or lean.do a fuel pump rewire and all the "free mods". i noticed in your profile you said you had an intercooler, is front mount? if so thats good. the stock side mount IC gets heat soaked real easy. you can run a 16g on without new fuel management it will spool quicker and hold boost better but don't set it any higher than 12 psi untill you get fuel management and bigger injectors. the 16g even at low boost will feel and be way faster than that t25 that comes stock on the 2g eclipses. to take full advantage of the 16g you will need a fuel pump that pushes more, bigger injectors, fuel management, front mount IC,and a datalogger.
zer0
"It's like playing rock, paper, scissors and sucker punch to the throat. The sucker punch always wins."
Old 07-15-2003, 09:52 PM
Talon007's Avatar
Talon007 Talon007 is offline
Send a message via MSN to Talon007
How fast do you wanna go? The T-25 is good for mid to low 13s. Plus the 16G isnt even a direct bolt-on.
Chris Clark
www.Talon007.com
1990 Eagle Talon TSi AWD - In Progress
1993 Eagle Talon TSi AWD - Parts Car
1990 Eagle Talon ESi - Sold
1-800-VFAQ - Bookmark it, read it, use it
Old 07-15-2003, 10:16 PM
I want another 50-75hp that i can have with a turbo and a mod . And in the future ( money doesnt grow on trees) do the full out process of fuel management.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-15-2003, 10:27 PM
zer0bot's Avatar
you can go with the 14b that comes on the first gens and do the fuel pump rewire turn up the boost a little then BAM there you go the hp you requested and not for that much$$$
zer0
Old 07-15-2003, 10:30 PM
but also something with some potential that gives me HP now , and in 6 months with mods will be even a bigger beast.
Mods :
-K&N Filter
-MBC
-Turbo Intake
-BOV
-2 inch Drop
-17" rims
-Indigo Gauges
Old 07-15-2003, 10:58 PM
zer0bot's Avatar
then read what i said in the post before and that should fit your
plans perfectly
zer0
How could my 95 GSX keep up with my friends' RB26DETT'ed 240's Venami Off-Topic 2 08-24-2010 08:25 AM
How to install 91 gsx downpipe? help... sentoyang Bolt on Parts 4 10-22-2009 08:09 PM
Not only do I love Honda's I also love the Eclipse GSX SolReaver Off-Topic 15 03-03-2005 01:28 PM
Acura Integra Type R vs Eclipse GSX GOD Car Comparisons 59 09-20-2004 06:29 PM
