Go Back   Automotive Forums Car Chat > Buick > Tips and Maintenance Procedures
Tips and Maintenance Procedures Post helpful tips, maintenance guides and R&R procedures for all Buick models here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-14-2003, 08:22 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Programming Remotes from 1998 to 2004
I will post every Buick on how to program remotes. I will put all years from 1996 to 2004 by model.
Transmitter Synchronization (This works on all GM cars and trucks)
Resynchronization may be necessary due to the security method used by the remote keyless entry system. The transmitter does not send the same signal twice to the remote control door lock receiver (RCDLR).
The RCDLR will not respond to a signal that has been sent previously. This prevents anyone from recording and playing back the signal from the transmitter.
Resynchronization may be necessary under the following conditions:
The battery in the transmitter is very weak.
The battery in the transmitter was replaced.
The battery in the vehicle has been in a low or no charge condition for an extended period of time.
In order to resynchronize the transmitter with the RCDLR, perform the following steps:
Stand within 1.5 m (5 ft) from the vehicle.
Simultaneously press and hold the LOCK and UNLOCK buttons on the transmitter for 7 seconds.The horn should chirp in order to confirm synchronization.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Closed Thread
