Old 07-14-2003, 08:16 PM
91dx 91dx is offline
AF Cutter
Thumbs down I need some advice plz
I am having crazy power loss. It sounds like my cars going some where but it isn't... My alternator is crappy and I think it went out could that be the cause of my power loss problem????? The check engine light came on eariler but I know for a fact my cooling system and oil is all good. so it has to be somthing else.. any suggestion is great thanks. peace
Old 07-14-2003, 08:33 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
could be ur clutch
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
when u got them power loss.. how fast u goin ? or how fast can u get ?? if its that bad.. it might be yer catalytic converter.. if u drove over a curb or hit somin pretty bad and messed up yer catalytic converter.. all that shit in there could break up and block yer exhuast passage.. that MIGHT be it.. but not sure exactly how yer cars actin' up
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
Old 07-14-2003, 08:51 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
Well it could be a code 16 (the ECU code would help us a lot to determine your problem!) which happens to a lot of cars. Run some fuel injector cleaner through your next full tank of gas to start, see how that does. If it IS a code 16, try changing your fuel filter. You might need new injectors if it is a BAD code 16. Also, reset your ECU.
Old 07-14-2003, 09:32 PM
AF Cutter
ok lemme be more detailed. sorry I was in a rush when I posted. OK ..
guys its just all around slow.. slow off the start and died even twice, then I can like hear the vtec and stuff kick in but it's so boggy like somethings holding it all back.. i dunno but I wasn't having problems with the fuel pump before the swap, but I dunno about the injectors I did clean them though. hmm I'm going to buy an alternator tomorrow because this one is 100% gone for sure. That's why I asked could this be the problem... hmm I dunno I've got to much in this i'm almost just about to say F*$% it and give up
any suggestions are great thanks guys
Old 07-14-2003, 09:34 PM
AF Cutter
i doubt its the clutch cause I just adjusted it.. it feels strong and perfect.
Old 07-14-2003, 09:47 PM
acuraattack92 acuraattack92 is offline
you should check your ignition timing and also see if you have ecu problems. Some 4th gen had problems with water getting on the ecu and f$%#ing everything up. The vtec might also be engaging way too early causing your car to bog and stumble on acceleration.
Old 07-14-2003, 09:49 PM
AF Cutter
I just bought a new pr3 ecu so I don't think thats the problem either.
Old 07-14-2003, 09:53 PM
Well then it might be something that is really simple or unfortunately an internals problem like compression loss.
Old 07-15-2003, 07:18 AM
SiZ's Avatar
SiZ SiZ is offline
Post up what code its throwing. Its hard to help if we don't know what the problem is.
Maybe your timing belt jumped a tooth!?!
"The nympho of info, I'm fuckin' what ya heard"
Old 07-15-2003, 11:03 AM
AF Cutter
iight i'll take it to auto zone and get the code after I get the new alternator on
Old 07-15-2003, 11:10 AM
quiXilver's Avatar
quiXilver quiXilver is offline
Send a message via ICQ to quiXilver Send a message via AIM to quiXilver Send a message via Yahoo to quiXilver
Yea, man i agree with the other dude, it mad sounds like your timing jumped a tooth, 'cause that same shit happend to me when my timing was fucked up, I could barely get the thing to move from a stop without like revving the hell outta it.
http://www.cardomain.com/quixilver09
B18A
-It's always somethin'
Old 07-15-2003, 01:13 PM
AF Cutter
yea thats exactly it... and when I get up to about 70 or so it finally goes pretty quick.
I just bought an RVM crank (only alternator) pulley last nite
also im going to get venom fuel rail, injectors, and fuel pump this week just to eliminate all them possibilties of it being the fuel.
hope its just the timeing! im going to check now.. later and THANKS
Old 07-15-2003, 03:51 PM
SiZ's Avatar
SiZ SiZ is offline
Just take the cover off the ECU (by the passengers feet), turn the key to the 1st position, and count the number of blinks from the light on the ECU.
Its easy to check the code in like 1 minute.
Old 07-15-2003, 05:08 PM
AF Cutter
nice thanks will do .. I made sure the timeing was on and it is... so now im going to go check that ... be back in a bit with results.
