Old 07-14-2003, 02:52 PM
hobbes874's Avatar
hobbes874 hobbes874 is offline
Send a message via AIM to hobbes874
Question Clearcoating question?
I used search but nothing came up that really answered my question. I'm a little confused on when clearcoating should be used. I'm planning on building a Tamiya Subaru WRC 2001 model which has a large # of decals and I'm wondering if I should clearcoat over the decals to protect them, because on all of my other models the decals just scratch right off!!
All Newbies please read the F.A.Q's
"We are defined by the choices we make." -Fight Club
Old 07-14-2003, 02:59 PM
jeffsgotaciv98 jeffsgotaciv98 is offline
Send a message via AIM to jeffsgotaciv98
Yes, whenever I use decals, I clearcoat over them. But I have had some decals turn a funny yellow so do a test. HAHAHA, thats funny your from Buque, NM to.
Old 07-14-2003, 03:09 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
dont use dupli color or any else laquer based clear coat to cover decals... they eat the decals away.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-14-2003, 03:10 PM
MR-2RaCeR's Avatar
MR-2RaCeR MR-2RaCeR is offline
Send a message via AIM to MR-2RaCeR
Clearcoat will protect the decals as well as making ur model shine.
-Henry-
Old 07-14-2003, 04:33 PM
hobbes874's Avatar
Will Tamiya's clear work fine? I've also read about other things like "Future", "Kleer"and "TopFlite LustreKote"?
Old 07-14-2003, 04:50 PM
Vric's Avatar
Vric Vric is offline
They don't "eat" decals, but they made an horrible job
Use Tamiya or Testor clear (testor #1814 ONLY)
Old 07-14-2003, 10:56 PM
cartuner's Avatar
cartuner cartuner is offline
Strange i have used dupli color clear top coat over decals before on some thing like 20 models and i have never run into any troubles regardless of of whom the model maker was.
Old 07-14-2003, 11:14 PM
MR-2RaCeR's Avatar
Try using Testors enamel clear coat, sumone i knew used Tamiya lacquer clear coat and it melted the paint off...
-Henry-
Old 07-14-2003, 11:24 PM
spoolin12's Avatar
spoolin12 spoolin12 is offline
Send a message via MSN to spoolin12
Im just in the mids of painting my focus and i used tamiya metalic gold and now i am clear coating with tamiya clear and its working fine!
Complete:
Old 07-14-2003, 11:53 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
the reason Tamiya clear coat ate the paint off was probably because he had use a non-lacquer paint color under the Tamiya lacquer clear. people need to be careful about paint compatibility.
Old 07-15-2003, 01:35 AM
fredo fredo is offline
You will also avoid many problems if you think to put a few "light mist" coats before the "wet coats". So you protect your paint and decals from any nasty thinner in the clear coat.
I learned that from P-Man
Frederic
Old 07-15-2003, 02:49 AM
chipanggo's Avatar
chipanggo chipanggo is offline
Old 07-15-2003, 05:53 AM
doraemon doraemon is offline
Yes yes, first 2 coats from long distance to protect the decals from the wet ones, this way the clear reach almost dry, and dont harm the decals, also, to be more sure, you can varnish the decals with tamiya ACRILYC clear with an airbrush to protect them more, but you still have to be carefull with the clear, this way you only have more protection, but no 100%!!!
Old 07-15-2003, 08:04 AM
Vric's Avatar
I did use testor clear if I need to spray over decals.. but only #1814. other clear are crap
Old 07-15-2003, 09:54 AM
hobbes874's Avatar
Thanks everyone
