Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-19-2001, 07:30 AM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
R33 GTR and Boost solenoid.
Ok, I pulled out the restrictor on a 97 R33 GTR VSPEC. The boost is now at around 14.5psi.
Now on that car, the restrictor was on the front pipe going to the solenoid. Just pulled it off and got rid of the restrictor.
Now the weird thing.... I was looking on a 95 R33 GTR, and the pipes were round the other way.... with the pipe with the restrictor in on the right hand side when looking from the front of the car..??
Is there something different from each model, or has it been messed with.. what would happen if the pipes were on the wrong way??
Ben
SDU Southland Moderator
Old 11-19-2001, 01:23 PM
Brenhan Brenhan is offline
Send a message via ICQ to Brenhan
hmmm , mine came in from the side of the solenoid , and all pics of them that I have seen have done the same . dont know if they changed them or not .
OT Skyline crew #001
Old 11-19-2001, 05:42 PM
GTS-4 Ben's Avatar
very odd indeed..
Old 01-26-2003, 04:02 AM
Erks Erks is offline
Hey guys, was just reading your posts, l just bought a gtr vspec r33 and was wondering if u can give me some tips. l also removed my boost restricter but am not sure it actually did anything as the ar still feels the same can you help please, maybe l did something wrong, but l did get the littlle brass thing out of the hose.
thanks guys..
Old 01-26-2003, 02:24 PM
RazorGTR's Avatar
RazorGTR RazorGTR is offline
Skyline Man
That is so weird. By removing it the car should have went from producing .65 bar to .9 to 1. bar of boost. I was the same on my R32. You very well could have a bad solinoid or it is not getting power.
If you know anyone else with a GTR see if you can borrow his/hers. What the plug does is restrict the amount of air release or boost bled off if you will.
You don't own a Skyline, then don't cry to me about it!
1992 Silver R32 GTR tickled to 450hp. - Sold when I left NZ in 2004
Arguing on the Internet is like competing in the special olympics. Even if you win, you're still retarded.
Never confuse kindess with weakness.
AF user guidelines, Please remember to abide by them
Old 03-13-2003, 08:23 AM
Bayside34's Avatar
Bayside34 Bayside34 is offline
Is this Brass Restrictor Mod Dangerous?
I've been told this is dangerous. Is it?
Can this same trick be done on the R34 GT-R? Someone told me you need to go to a tuner and get them to check the boost level. One guy actually told me his boost went to 1.4 bar upon removing his brass restrictor...
Will this be safe on a completely standard year 2000 R34 GT-R V-Spec ?
What will the max boost peak at then? I've seen it peak at 1.03 bar on the MFD before now but not very often.
Trev
Old 03-13-2003, 08:41 AM
RazorGTR's Avatar
Skyline Man
Each generation Nissan has done different things. On the R32 and R33 it seems to be some sort of bleed off system rather than a restrictor.
Trev I beleive the ECU controlls the boost level on the R34, so removing it may have adverse effects but honestly I will have to check into it. I am not as familuar with the R34 setup in that aspect as I am with the R32 and R33. Either way the factory ECU should have a boost cut simular to the late R33 GTR's.
Old 03-13-2003, 08:57 AM
Bayside34's Avatar
Thanks for the reply.
Did you have to increase the fueling with a remapped ecu (e.g. Apexi PowerFC) to do this mod safely or does it work without? What about compression ratio, did you fit a HKS Metal Head Gasket to stop any detonation? What about timing, was it retarded by a few degree's to stop det? Or did this all just work happily without any other mods?
Do you know what is the maximum bar/psi the turbo's can reliably take before going 'pop' and being consumed by the engine (i.e. requiring a full engine rebuild and new turbo's - not cheap!)
Sorry if I've got lots of questions, I just don't want to blow up the engine on my car!
Old 03-29-2003, 07:24 PM
tyndago tyndago is offline
Send a message via AIM to tyndago
The solenoid only opens and closes so it doesnt really matter which way the hoses are hooked up as far as I can tell...
Most of the time the line with the restrictor goes out to the right when you are looking at it from the front.... towards the passenger side..
Sean Morris
http://www.2009gtr.com
http://www.gtrusablog.com
