Old 07-14-2003, 10:46 AM
Davoaldo Davoaldo is offline
Enamel Paint Brush Painting
Just wondering cause i never used enamel paitn before......
what do i use to clean brushes when i want to change colour
cause like for acrylic i use sue a pot fo water and jsut keep using it...
but is there anythign like used for enamel??
Also ppl who have been using enamel for ages do enamal like dry out or are not usuable after like sitting there 1 year without being touched as in stored away??
Thank for help
Old 07-14-2003, 11:29 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
It depends on what brand of enamels you're using. Humbrol, for example make their own thinners to wash brushes with. However, White spirit will remove paint just as well.
I think it is safe to store enamels for a while as long as the containers are shut properly. If not they'll just dry out. I've had my enamels for about 5 years, however, when I want to use them, I'll have to stir them as the pigments have settled at the bottom.
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
you have to use Mineral Spirits to clean enamel. it takes a day or more to dry to touch. a couple weeks to completely set and cure.
Old 07-14-2003, 12:33 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Use some lighter fluid in a small cup to clean enamels.
Follow that with a thorough washing with soap and water, and you're ready to paint again.
Old 07-14-2003, 12:38 PM
freakmech's Avatar
ummm... i think you should just get some mineral spirit. lighter fluid? im sure it works but really mineral spirits are cheap and effective and well... dont sound as dangerous
Old 07-14-2003, 12:41 PM
Personally I'm not too fond of the smell of mineral spirits
What I use is ronsonol ligher fluid for zippo-style lighters. I never have any to dispose of, because the fluid evaporates overnight after I'm done cleaning brushes.
Old 07-14-2003, 01:02 PM
wow..... enamel cleanign stuff sound so toxic compare to acrylic...... i think i might stay with acrylic unless i need to do large areas........
cause these tamiya enamel thinner stinks.......
Old 07-14-2003, 01:17 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
for testors, you need to use Testor Enamel Thinner. Regular paint thinner wont work..
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-14-2003, 02:45 PM
008's Avatar
008 008 is offline
I only use enamel when I'm airbrushing small items like chassis, suspension parts, etc out in the garage with a respirator. For detail painting small items while sitting at my desk acrylics are the way to go. As mentioned earlier, all you need is a cup of water and you're set for a while. The only enamels I use at my desk are the shiny stuff like silver, aluminum, etc and only if I absolutely have to.
Old 07-14-2003, 03:24 PM
Well i use acrylics mostly but enamel seems to spread otu easier and more even......
Old 07-14-2003, 07:34 PM
themodelkid's Avatar
themodelkid themodelkid is offline
Send a message via AIM to themodelkid
I use lacquer thinner!!! 5 gallons of it. It will clean anything, paint thinner or mineral spirit's suck monkey nuts compared to lacquer thinner.
themodelkid-Frank
2004 Dodge Intrepid SXT 3.5L HO
Brilliant Black Crystal Prl. Metallic
250hp, 250 lb ft tq.
1995 Dodge Intrepid 3.5L
Stone White
230 hp, 246 lb ft tq.
Supercharger in Works...
1987 Chevy S-10
Midnight Blue Prl. Metallic
300hp, 314 lb ft tq.
5.0L Baby...
