Old 07-14-2003, 08:46 AM
bigaldover bigaldover is offline
89 S10 ABS Error code 3
Hi Everyone.
My Brake light flashes 3 times then one long flash. This looks to be a code 3 open dump valve. Does anyone know wher the dump valve is located ?
In my readings, the modulator/dump valve are the same.
Anyone know anything about this ?
Suggestions or advice is greatly appreciated.
Allan
"If you done it, it aint braggin" Roy Rogers
Old 08-02-2003, 06:02 PM
Smile Corosion
Hello everyone,
The dump valve contact wire harness was corroded. I eplaced it, and reset my ecmb and brake circuit.
Everything works fine.
So if someone has an abs brake problem really check all the wiring.
Allan
