LeSabre Keyless Entry Questions CHECK HERE BEFORE POSTING!
2000 lesabre limited keyless programming
Actually, I have a 2000 Lesabre Limited....right in between what you have listed. Sorry!
Any advice that you have to offer would be great. Thanks. |
I noticed thatm and unfortunatly, I have no knowledge of programming keyless entrys on any LeSabre, hopefully Flatrater can sort it out for you.
Re: 2000 lesabre limited keyless programming
Important All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon the receipt of the programming signal from the first transmitter. Up to four transmitters may be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. The number on the transmitters are for reference only: #2 can be programmed as #1, or vice versa. Additional unnumbered transmitters are also available. Use care to program the transmitters correctly. Install a scan tool. Turn ON the ignition, with the engine OFF. Use the scan tool Remote Function Actuation Special Function: Program Key Fobs in order to place the remote control door lock receiver into Program Mode. The doors will lock and then unlock in order to confirm program mode. Important The scan tool must stay connected until all of the transmitters are programmed. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 15 seconds, the doors will lock and unlock in order to confirm the programming of that transmitter. Repeat the previous step in order to program up to 4 transmitters. Remove the scan tool. Operate the transmitter functions in order to verify correct system operation. |
Re: LeSabre Keyless Entry Questions CHECK HERE BEFORE POSTING!
That picture of your dash is great but it looks like you have the highest gears Ive ever seen.
Heh, yeah I was in overdrive and coasting down from 112 mph so the rpms came down quite a bit.
Sigh.
Pretty sure that I have a '96 LeSabre.. people keep mentioning the "8-pin connector" thing, but it LOOKS as if mine is some bizzare 9-10 pin.. didn't bother to count exactly, but I know it is for SURE over the "8" number. Plus, all the pictures seem to be broken.. can't get a decent look at what I should be looking at! Any help to be had? |
Factory Remote won't program
I have a 97 LeSabre. My dad got a aftermarket keyless remote and programed it (Your Valet). Works fine. I bought the car and got a Factory GM Remote. It is the right numbers, had it tested at the dealer, so I know it works. I tried to program it to my car but nothing happends. How come the Factory FOB won't program?
I have a 2002 le sabre with remote. There is no battery in the remote. Can anyone tell me the battery size/specs? Radio shak is unsure.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Thread Closed!
Knowledge can be communicated, but not wisdom! ![]() ![]() |
