Go Back   Automotive Forums Car Chat > Nissan > Skyline | Skyline GT-R | Stagea | Laurel > Performance
Performance Discussion about performance modifications and issues.
Old 11-19-2001, 01:36 AM
YCEE YCEE is offline
Adjustable Fuel Pressure Regulator
What are the pressure of the factory regulator on a GTR?
How much pressure should an adjustable pres. regulator set to?
I remember someone saying that you should set the pressure regulator with the vacuum hose unplug???
What will happen if I set it too high or too low?
Old 11-19-2001, 04:15 AM
turbomad turbomad is offline
If you lift your base fuel pressure you will flood the engine at low to mid RPM's unless you have an adjustable ECU or interceptor fitted, in which case lifting fuel pressure is a good way of squeezing a few more HP out of your standard injectors.
Old 11-19-2001, 06:13 PM
WDRacing WDRacing is offline
A cheap way to increase fuel pressure is to simply restrict the return more then the regulator already does. Install a restrictor, crimp a line. Take your pick...
WD
WDRacing
Its all in the name
Old 11-19-2001, 06:42 PM
GTS-4 Ben's Avatar
GTS-4 Ben GTS-4 Ben is offline
Send a message via ICQ to GTS-4 Ben
How much to you squeeze it. Surly too much would be bad.. does it make the car run rich always?
SDU Southland Moderator
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
