Go Back   Automotive Forums Car Chat > Mazda > MX-6
Old 07-13-2003, 06:39 PM
theo_6 theo_6 is offline
Question Headlights......
I am having problems with my headlights. When they are on regular, you can't harldy see them at night, and when you put them on bright, they look like they should when they are on low! Alos, my bright indicator is always on whether they are on bright or not. I have changed the bulbs, and cleaned the covers, but nothing helps. Most peoples headlights are brighter on low than mine are on bright! Any help would be appreciated, thanx. By the way, it is a 95 mx6
Lincoln T Pratt
Old 07-13-2003, 09:16 PM
robflanker robflanker is offline
agreed.
i have the same problem, my headlights r terrible.
i have a 1992 mx-6
Any solutions?
Old 07-17-2003, 02:24 AM
JJJJJrio JJJJJrio is offline
Talking Same here..
Got my 1992 mx-6.. My headlights are dim too... havent gotten around to fix them since I rarely drive at night ( got the harley truck fer cruisn, mx-6 fer work). Anyone got an Idea.. maybe its a fuse??
Old 07-17-2003, 02:34 AM
the only thing I know is...
The mechanic told me there was probably a short in the wires somewhere, I would just have to try and find it. He wanted too much money todo it, and I know nothing about it myself, so I guess I will just have to keep using my fog lights with my dim headlights......unless anyone knows something I don't
Lincoln T Pratt
Old 07-18-2003, 11:20 PM
I fixed my problem. Fuse was bad.. checkout the fuse in the engine compartment. Its the third from last facing the car.
Old 07-30-2003, 03:50 PM
daze daze is offline
Is it the headlight bulbs or the crappy Lexan lenses. They tend to turn yellow and it seems to dull your brightness. You can get rubbing compound or NeverDull at wallyworld and rub/buff. Or you can go with
espec glass lenses or aftermarket if you got the cash. You might try a little bit brighter bulb...maybe 10 more watts. I would be careful going too high on wattage, might melt the bulb housing.
Old 07-31-2003, 09:08 AM
I don't know.....
I took the lenses off, and cleaned them about three times, and hte last time I used Neverdull. It made them a little brighter, but nowhere near what they should be. I already tried the brighter bulb, and it didn't help. It is beyond me.
Lincoln T Pratt
Old 02-11-2006, 08:30 PM
Monster4922 Monster4922 is offline
Re: Headlights......
Try The Grounding Wire/Grounding Things.
Old 09-11-2006, 12:00 PM
teqshot teqshot is offline
did you try the fuse
