Old 07-13-2003, 06:35 PM
metroman metroman is offline
Angry transmission problem
I have a 1993 Geo Metro with automatic transmission. When I first drive the car, it shifts fine, but after a few minutes, it won't shift right and I have no revese gear. If I let it sit a while, it shifts fine again (including reverse) but then after a few minutes it starts all over again. Any ideas?
Old 07-13-2003, 07:47 PM
geozukigti geozukigti is offline
Get a fluid flush. The tranny fliud is prolly no good. Also check the fluid level.
Old 07-13-2003, 08:21 PM
The tranny fluid is full and it's not too old. It had been changed at one time. Why does it do this after a period of time. Is it heat related?
Old 07-14-2003, 07:31 AM
sounds like it is heat related. Is your radiator ok? The transmission cooler is built into the radiator. The lines could possibly be plugged up, and not cooling the trans. Try hooking up a cheap transmission cooler from autozone to the oil lines from the tranny.
Old 07-14-2003, 08:47 AM
I will give that a try. I guess I might as well change the fluid and filter and see if that takes care of it. Do you think, then, it is the fluid casing it? That would be much better than putting a new tranny in! Thanks for the help.
Old 07-19-2003, 02:27 PM
Thumbs up
Problem solved!! I changed the tranny fluid and filter and it shifts fine again. Thanks again for the help!
Old 02-14-2004, 09:14 PM
1993bgm 1993bgm is offline
Re: transmission problem
have 93 myself with trannie trouble
get cheapest look at trannie place may be bearings or valocity joint
Old 03-29-2004, 07:40 PM
kltuck kltuck is offline
Same Problem
I had the same problem in my 92 (1.0l.) Replaced the filter and fluid. Replaced the radiator ($10.00.) Finally replaced the Tranny ($50.00 + 120.00 for all new seals and gaskets and some tools.) Runs like a top now
Old 02-01-2009, 10:50 PM
s10drew s10drew is offline
i have a 98 metro lsi where can i get transmission parts cant find anything any where
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
