Old 07-13-2003, 03:10 PM
blacksheep blacksheep is offline
Send a message via Yahoo to blacksheep
Unhappy odd starting problem
my civic is having trouble starting, the self diagnostics says its the fuel injectors, but they are fine, if it doesnt start i can wait a few minutes and try again and it fires right up, i dunno what is wrong with it cause it starts when it wants to. if anyone has any ideas it would help?
Old 07-13-2003, 03:14 PM
Dumped91Hatch's Avatar
Dumped91Hatch Dumped91Hatch is offline
what exactly does it do when it wont start? Is it just dead do u get your instrument lights? does it just click? does it turn over?
Check out my car here My 91 Hatch
Old 07-13-2003, 03:16 PM
chopstick1981 chopstick1981 is offline
does it start when its cold and hasn't been run for a while, but then wont start when its warmed up and you try and restart it?
Old 07-13-2003, 03:21 PM
it cranks over and all the instrument lights turn on, but it doesnt fire for some reason the fuel wont go to the spark plugs cause ther not wet or anything when it dont start but it will start when it wants to, usaully starts in the cold and sometimes it dont
Old 07-13-2003, 03:24 PM
It sounds like its either a cloged fuel filter or the fuel pump
Old 07-13-2003, 03:28 PM
the fuel filter is fine and fuel pump runs when u turn the ignitoin i think its one of the censors that control the injectors but dont no wich one, it could be the throttle position censor but they cant be replaced, and you cant buy em anywhere
Old 07-13-2003, 05:02 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
whens the last time you did a basic tune up?
Old 07-13-2003, 06:38 PM
jtda jtda is offline
My civic would occasionaly have a hard time starting if the first turn of the key failed. On succesive start attempts, the engine would crank its heart away but not start- there was no combustion at all, but a very strong turn over. This was very rare, and occured only a few times over 2 years. In its final few months, it became much worse, especially as it began to occur on my FIRST start attempt.
I suspected my fuel pump, and as per the maual, removed the fuel tank to test my pump directly, which was a ok. Fuck you Honda. It was just my relay. Lots of wasted effort.
What I realised about the relay is that sometimes one of the switches inside it wouldn't click, leaving the fuel pump without electricity.
Here's a link.
http://www.suntimes.com/output/ebert...-later27f.html
And another link that might help you. It has more info, as well as a how to for Main Relay replacement.
http://www.fourthgenhatch.com/index2.html
Old 07-13-2003, 06:56 PM
b16rex b16rex is offline
Send a message via MSN to b16rex Send a message via Yahoo to b16rex
my crx had the same problem. it would turn over but wouldn't start sometimes. i put a new igniter in and solved the problem.
-1994 Civic coupe DX
Old 07-13-2003, 10:58 PM
maybe its the main relay cause i just read on 4th gen hatchbak that they dont werk good in warm temp and i havent had the problem until it got really warm out, and it werked all winter
Old 07-13-2003, 11:49 PM
DarkImportGrey's Avatar
DarkImportGrey DarkImportGrey is offline
Send a message via AIM to DarkImportGrey Send a message via MSN to DarkImportGrey Send a message via Yahoo to DarkImportGrey
most likely the relay... on most hondas between 88 - 91 or so this is a common problem... i've had the problem in my car when i got it, my ex girl's 3G accord had it, my mom's 90 accord had it...
Old 07-14-2003, 10:23 PM
i tested the relay when it got warm and didnt werk so i ordered a new one
thanks
Old 07-14-2003, 10:48 PM
KoRnSaQ KoRnSaQ is offline
Send a message via Yahoo to KoRnSaQ
Ya, i have to agree, i think it is the main relay. My friend had the same problem with his CRX. He had to turn the key on until the oil light went off, then he would crank it over, and it would start. So you might want to try that until you can get it fixed.
