Old 07-13-2003, 02:52 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Bending Aluminum tube
How do you do it and not kink the tube? I've used those little metal coil spring bender things, but they always end up kinking, anyway, and the tube gets stuck in it. Am I a moron?
Old 07-13-2003, 03:56 PM
hiver77's Avatar
hiver77 hiver77 is offline
try putting a solid metal rod inside it and then bend?
I heard that works.
In the finishing stage:
Old 07-13-2003, 04:00 PM
Tercel GTS Tercel GTS is offline
Send a message via Yahoo to Tercel GTS
go to a parts store and get the pliers looking brake line bender, they also sell'm at sears
click to chat at StonerScript
Old 07-13-2003, 05:41 PM
Lambo003's Avatar
Lambo003 Lambo003 is offline
Copper wire works well for me . . . a bit smaller than the ID of the tube you're bending and preferably the vinyl coated strand wire rather than solid core. The vinyl "GIVES" when you try to remove it from the bent tube.
Old 07-13-2003, 06:47 PM
Hawk312 Hawk312 is offline
I`ve had success with using solder inside the tubing. It bends real easy.
WANTED! 1/12 Corvettes and Camaros.
Newest builds. Click on images to go to the thread:
1/12th `69 Z/28 Camaro and 1/12 `67 Corvettes
Old 07-13-2003, 07:10 PM
If its alluminum you can heat it up and *with some gloves* bend it to your liking.
Old 07-13-2003, 08:01 PM
Diesel2NR's Avatar
Diesel2NR Diesel2NR is offline
Send a message via AIM to Diesel2NR Send a message via Yahoo to Diesel2NR
I know one of my buddies in engineering classes was taught to fill the tube with sand and cap the ends, then bend it. Kept it from kinking nicely, and was pretty cheap.
Old 07-13-2003, 08:05 PM
primera man's Avatar
"P-Man"
JACKPOT !!
View All My Models Here.
Old 07-13-2003, 09:31 PM
Diesel2NR's Avatar
JACKPOT !!
Exactly. It's cheap, and it works. Just be sure that if you leave some extra length at the ends so you can cut the caps off...if you actually glue them on. I never paid attention to how my friend did it.
Old 07-14-2003, 12:15 AM
TURBOSATURN's Avatar
TURBOSATURN TURBOSATURN is offline
So what, would i use for caps??? and do i fill the whole tube with sand?
Old 07-14-2003, 12:22 AM
Sounds like a good idea, and I can get access to sand very easily!
AF MODELING FAQ
"Oh what a feeling.- Toyota
Old 07-14-2003, 03:09 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
I heat the tubing with a butane torch and let it cool, when it's cool its soft as butter. If you need it hard again, just heat it and cool it quickly in some water.
Old 07-14-2003, 08:23 PM
jdmwhizkid's Avatar
jdmwhizkid jdmwhizkid is offline
Cap the ends with some white glue and let it dry. It usually does a good job of holding the sand inside.
Old 07-15-2003, 05:41 AM
chrismcgee's Avatar
chrismcgee chrismcgee is offline
WWW.ELITESCALECARS.CO.UK
the heating process of aluminium is called anealing, basicaly you re arrange the molecules of the aluminium making it a bit more maliable. i think the temp is about 470 deg celcius, but the best way is to rub a bar of soap onto the aluminium and when the soap turns brown you have reached the temperature needed to aneal.
